Inkscape Gcodetools
15 Mar 2020 02:13 #160248
by curnowdj
Inkscape Gcodetools was created by curnowdj
G'Day Gang,
I am playing around with Inkscape Gcodetools and find the gcode that is generated has a lot of travel from one end to the other often. I simulate in Camotics.
Can you tell me if there is something in the setup of Gcode tools that will sort the travel moves to start at one end and work through to the other end?
TIA
TIA
- Thank you received: 5944
15 Mar 2020 03:04 #160253
Replied by tommylight on topic Inkscape Gcodetools
Extensions>gcodetools>path to gcode> there is "sort paths to reduse rapid distance"
Click that.
It is misspelled there, it should be "reduce" .
Click that.
The following user(s) said Thank You: curnowdj
15 Mar 2020 03:29 - 15 Mar 2020 11:15 #160254
by curnowdj
Replied by curnowdj on topic Inkscape Gcodetools
Hello,
I have attached a ngc file that still goes all over the shop in the simulator and the svg from Inkscape. I ticked the sort path box in the Gcodetools but didn't seem to make any difference. I had the sort box checked already.
Cheers
PS: I had attached a .nc file that I can't seem to delete. I have clicked on the remove button but does not remove file.
Cheers
Last edit: 15 Mar 2020 11:15 by tommylight. Reason: Attachement was not showing
15 Mar 2020 11:14 - 15 Mar 2020 11:17 #160280
WTH?
I can not see the attachment, but if i chose to quote, it does show as attached !
Edited, it shows now.
Can you also attach the svg ?
Last edit: 15 Mar 2020 11:17 by tommylight.
15 Mar 2020 23:39 #160368
by curnowdj
Don't know what happened with the svg yesterday because I did attach it but here it is again.
16 Mar 2020 09:26 #160397
Moderators: Skullworks
