flood fill algorithm
08 May 2023 23:11 #270970
by clive
flood fill algorithm was created by clive
I have done a brief internet search looking for a flood-fill algorithm. That is an algorithm to clear/mill and arbitrarily shaped region on a woodblock.I know there has to be commercial tools that do this but, for the moment, I'd like to incorporate it into my own CAM/G-Code tool.Can anyone point me to some pseudo code please.https://www.royalacademy.org.uk/article/felix-vallotton-beginners-guide
- Online
- Thank you received: 5952
09 May 2023 00:30 #270975
Replied by tommylight on topic flood fill algorithm
Why the link?
Does it have to do with the question?
09 May 2023 14:19 #271028
by clive
Replied by clive on topic flood fill algorithm
It is the kind of carving I want to do. Vallotton made quite remarkable woodblock prints. Very simple, black and white blocks. In his case hand carved.
A basic pixel image flood fill algorithm is easy but for a CNC cut with a finite tool size, it seems much harder.
Maybe I should just explore inkscape ?
09 May 2023 16:16 - 09 May 2023 17:19 #271036
by clive
Is image-to-gcode already installed alongside LinuxCNC ? Can it be found as a separate program ?
I found this stand alone version on GitHub from five years ago but it is not in Python3 and will take a fair amount of time to clean up.
Last edit: 09 May 2023 17:19 by clive.
- Online
09 May 2023 17:19 #271043
Try this, i use it sometimes and i like it better than image2gcode.
It is derived from image2gcode, as it states at the top of the code, though.
www.scorchworks.com/Dmap2gcode/dmap2gcode.html
The following user(s) said Thank You: clive
09 May 2023 20:06 #271063
by clive
The dmapto2gcode looks to be what I should run.
The code uses a Python module called tkinter which isn't in my system. I installed it using pip but dmapto2gcode still can't find the module to import.
I'm not a regular Python user so figuring out where modules might reside is a puzzle.
09 May 2023 21:44 #271066
by clive
I have it working ! The issue is Python3 and compatible modules
I had to install a bunch of stuff:
sudo apt-get install python3-tk
sudo apt-get install python3-numpy
sudo apt-get install python3-pil
python3 -m pip install --upgrade pip
python3 -m pip install --upgrade Pillow
And then the program runs:
python3 ./dmap2gcode.py
I hope this helps others...
Moderators: Skullworks
Time to create page: 0.154 seconds
