DEB for linuxcnc HTML documentation
- twoflowers
- Topic Author
- User is blocked
- Thank you received: 32
20 Sep 2020 08:38 - 20 Sep 2020 08:38 #182842
by twoflowers
DEB for linuxcnc HTML documentation was created by twoflowers
I've made a deb with the HTML documentation of linuxcnc 2.8.0 - intended for all would like a browsable documentation on the machine (like myself). Feel free to include it on the ISOs or put it somewhere where people can find it easily.
linuxcnc-doc-html_2.8.0-1.deb
Last edit: 20 Sep 2020 08:38 by twoflowers.
The following user(s) said Thank You: BeagleBrainz
- BeagleBrainz
- User is blocked
- Thank you received: 570
20 Sep 2020 09:57 #182853
by BeagleBrainz
Replied by BeagleBrainz on topic DEB for linuxcnc HTML documentation
I did that on the first couple of Mint ISOs.
Did you come up with a fix for the javascript in the gcode refernce section ?
When you click on a gcode link you'll be sent to a page at linuxcnc.org
- twoflowers
- Topic Author
- User is blocked
20 Sep 2020 10:48 #182870
by twoflowers
Replied by twoflowers on topic DEB for linuxcnc HTML documentation
Which section are you referring to? I have not tested everything but as far as I can see all links are local.
- BeagleBrainz
- User is blocked
20 Sep 2020 10:53 #182872
by BeagleBrainz
G-Code Quick Reference.
Click on a GCode hyper link.
I tried to get a fix on this issue around April if memory serves me correct.
- twoflowers
- Topic Author
- User is blocked
20 Sep 2020 11:31 - 20 Sep 2020 11:38 #182880
by twoflowers
Ok, found it. You can safely remove the <SCRIPT ... >...</SCRIPT> at the end of file, then the links work as they should. Sideffect: you loose the banded background (which I see as a bonus). This is what I did in my package (just uploaded the new version).
Or you can just delete line 191 and 192 in gcode,html - they contain this text:
EDIT: If you really like the banded thingie, here's how to do it in CSS with 2 lines without javascript
www.w3.org/Style/Examples/007/evenodd.en.html
it.setAttribute('href',
"http://linuxcnc.org/docs/devel/html/" + it.getAttribute('href'));
Last edit: 20 Sep 2020 11:38 by twoflowers.
- BeagleBrainz
- User is blocked
20 Sep 2020 11:40 #182884
by BeagleBrainz
Good work
Might want to suggest this to the devs. Would be a good idea for those of us who don't connect their Linuxcnc boxes to outside world except to do updates.
- twoflowers
- Topic Author
- User is blocked
20 Sep 2020 16:53 #182926
by twoflowers
Where do I find the devs to contact?
- Thank you received: 5949
20 Sep 2020 16:57 #182928
Mailing list or IRC should be the fastest way.
Replied by tommylight on topic DEB for linuxcnc HTML documentation
linuxcnc.org/community/Where do I find the devs to contact?
Moderators: HansU
Time to create page: 0.267 seconds
