github use
- robertspark
- Thank you received: 216
30 Aug 2021 09:25 #219154
by robertspark
github use was created by robertspark
Is there like a numpties guide to using git for linuxcnc?
I've tried to update a few files, but am unsure as to how to create a pull request for these SPECIFIC files, and not all the files I've changed..... so that I can add a comment to each item ive changed?
github.com/robertspark/linuxcnc/commit/3...eee8409919bd30f493ac
github.com/LinuxCNC/linuxcnc/commit/82a7...257590c067bdd9760af6
30 Aug 2021 10:47 #219158
by phillc54
Replied by phillc54 on topic github use
There is none that I know of.
You can edit a file directly from a browser and then create a PR.
The following user(s) said Thank You: robertspark
30 Aug 2021 13:24 #219169
by Reinhard
Replied by Reinhard on topic github use
for my repos I use GitEye - very nice gui which supports drag&drop, shows diffs and much more. Its possible to do commit and push in one shot.
I like it much, but GitEye is limited to debian 10 - GitEye is a java app converted to binary, so any compatibilty has been lost
- snowgoer540
- Thank you received: 750
30 Aug 2021 14:21 #219172
by snowgoer540
Replied by snowgoer540 on topic github use
It looks like at least one of these just got taken care of:
github.com/LinuxCNC/linuxcnc/commit/e74e...069655df1de7166286a5
- robertspark
30 Aug 2021 15:21 #219174
by robertspark
Replied by robertspark on topic github use
Thanks all, I'm finding a few of these snafus' {syntax stuff}
sudo apt-get install qttools5.dev
which should be:
sudo apt-get install qttools5-dev {dash}
they are just easier to correct than waffle on about where:
linuxcnc.org/docs/devel/html/gui/qtvcp.html
Section 3.2
and
fine name error qttools5.dev "."(dot) to qttools5-dev "-"(dash)
github.com/LinuxCNC/linuxcnc/pull/1253
github.com/LinuxCNC/linuxcnc/pull/1252
see what happens
which should be:
Section 3.2
and
see what happens
- snowgoer540
30 Aug 2021 16:39 #219176
by snowgoer540
Good finds. It appears Rene committed them.
The git stuff gets easier, believe it or not haha.
Thanks for the effort!
31 Aug 2021 00:50 #219208
by phillc54
Robert, I don't know if you have seen this:
www.linuxcnc.org/docs/html/code/contributing-to-linuxcnc.html
Moderators: HansU
Time to create page: 0.170 seconds
