How to find specific files in the github
10 Sep 2021 16:36 #220141
by RékaM
How to find specific files in the github was created by RékaM
I've been poking around in the github directory trying to understand linuxcnc a bit better, but the files keep referring to other files which I just. Can't. Find. For example one .ini file I've been looking at to figure out my own .ini file refers to "5axis.var", but I can't find where it is and there's just so many files. It took me several minutes to find "basic_sim.tcl" and that one had the hint of "LIB:" in front of it in the file I was looking at. I can't find a search function on github, is there some kind of directory tree document or something that I could ctrl+f through to find where specific files are or do I just need to poke around until I find it?
- Thank you received: 5934
10 Sep 2021 17:07 - 10 Sep 2021 17:11 #220146
Replied by tommylight on topic How to find specific files in the github
"5axis.var" is created (if missing) when LinuxCNC starts.
The name will be whatever the name of the running config files is.
Last edit: 10 Sep 2021 17:11 by tommylight. Reason: more info
10 Sep 2021 17:28 #220149
by RékaM
Replied by RékaM on topic How to find specific files in the github
Oh. Thank you. I found it in the config file of a sim I'd already loaded.
Still, there are other files I've only been able to find after a lot of searching; since you didn't mention an easy-to-search document, would it be safe to assume there isn't one...? I don't mind searching around if I have to, but would like to make sure I'm not making it harder on myself than it has to be!
10 Sep 2021 17:41 #220151
Replied by Aciera on topic How to find specific files in the github
I'm not really using github much but here is a doc that might be helpful:
docs.github.com/en/github/searching-for-...ithub/searching-code
What I do is clone the github repository into a folder on my computer and then I can use the regular linux terminal comands like 'find'
10 Sep 2021 19:36 #220167
Replied by rodw on topic How to find specific files in the github
Git is a source repository. Some files are created as part of the make process from that source code.
You would probably be better off compiling a run in place version of linuxcnc and using grep to find files as everything will be under the linuxcnc-dev folder somewhere.
14 Jan 2022 07:52 #231734
hanamark
had to leave...
had to leave...
Moderators: HansU
Time to create page: 0.076 seconds
