How and where to report documentation problems????
04 Jun 2022 19:45 #244583
by Roguish
How and where to report documentation problems???? was created by Roguish
I recently found a documentation problem.
Essentially a woefully out of date html and pdf feature document. Confirmed with an active developer who definitely knows.
How and where should I report the problem ???
04 Jun 2022 19:52 #244585
Replied by cmorley on topic How and where to report documentation problems????
Well you could start here or/and add an issue in linuxcnc's github issue tracker.
Be advised docs system are being worked on in master and has some growing pains.
The following user(s) said Thank You: Roguish
04 Jun 2022 19:58 #244586
by Roguish
Replied by Roguish on topic How and where to report documentation problems????
I'll fill it in here, and look into the github issue tracker
Moderators: HansU
Time to create page: 0.143 seconds
