Pull Request for website [Closed]
13 Sep 2022 11:12 - 14 Sep 2022 05:56 #251799
by zz912
Pull Request for website [Closed] was created by zz912
I would like ask you. Is possible make Pull Request for website?
There is an error in the release description. There is definitely no PNCconfig support for the 7i96S card in version 2.8.3.
I made Issue:
github.com/LinuxCNC/linuxcnc/issues/1927
but nobody react.
If it was possible to make a Pull Request for the website, I could make the work of the developers here easier. It's just about deleting one line.
Many 7i96S card owners are waiting for support and this just confuses them.
I made Issue:
but nobody react.
Last edit: 14 Sep 2022 05:56 by zz912.
13 Sep 2022 23:58 #251857
Replied by rodw on topic Pull Request for website
Its not being ignored. Go back to your pull request and follow the links to other linked issues.
14 Sep 2022 05:55 #251874
by zz912
Replied by zz912 on topic Pull Request for website
Silopolis Jérémie Tarot helped me. So this problem is solved.
26 Sep 2022 13:32 #252764
The website is a separate repository under LinuxCNC called "wlo" (for Www.Linuxcnc.Org)
github.com/LinuxCNC/wlo
Replied by andypugh on topic Pull Request for website [Closed]
To answer the question, yes you can make pull requests and raise issues with the web site.I would like ask you. Is possible make Pull Request for website?
26 Sep 2022 13:34 #252765
by zz912
Replied by zz912 on topic Pull Request for website [Closed]
07 Dec 2023 00:57 #287401
by mBender
Replied by mBender on topic Pull Request for website [Closed]
Piggyback on this topic.
I submitted a pull request github.com/LinuxCNC/linuxcnc/blob/master...dating-linuxcnc.adoc
But this file on the website is still wrong. linuxcnc.org/docs/stable/html/getting-st...dating-linuxcnc.html
07 Dec 2023 01:03 #287402
by phillc54
Replied by phillc54 on topic Pull Request for website [Closed]
Possibly because the buildbot has been failing. The last completed update was on Nov 28.
buildbot.linuxcnc.org/buildbot/grid
07 Dec 2023 01:05 #287404
by mBender
How can I help to fix that?
07 Dec 2023 01:07 #287406
by phillc54
You cannot do much, I have reported it on the devs list.
The following user(s) said Thank You: mBender
Moderators: HansU
Time to create page: 0.292 seconds
