LinuxCNC Users Manual for Beginners
- Thank you received: 5933
Start with the users manual, or even better, cobble together a mchine and make it work, experience is the best teacher.
I do have a 3 axis 4 motors table router CNC running on Mach3 and this will be my experimental cnc to start learning. Obviously first I will have to learn the basic config of LinuxCNC and then remove Mach3 and install LinuxCNC
Download the 2.8.4 ISO image there, burn it to a USB stick, boot the PC from it.
When it boots to the desktop, menu find the cnc stuff, choose StepConf and create a config for your machine, save, start the new config and use the machine.
All that can be done from the USB, without installing anything on the PC, but beware that when rebooting nothing will be saved.
You can save that config to another USB or internal hard drive for later use.
My 3 axis 4 motors cnc runs now on Mach3. When I remove Mach3 and install LinuxCNC would all electronics I now have be suitable or LinuxCNC requires special electronics (like stepper motors, motor drivers, breakout board and spindle control?)
I found a link here dated April 2015 and it talks about parts I’m not aware.
If I need new electronics for the LinuxCNC where should I look for them in USA/Canada?
And the docs of the current development version 2.9 have been improved a lot the last time, so for general understanding I would recommend that: linuxcnc.org/docs/2.9/html/
It hasn't changed that many, mostly new functionality and hardware support was added.
If you continue using the parallel port, you can use exactly the same hardware.When I remove Mach3 and install LinuxCNC would all electronics I now have be suitable or LinuxCNC requires special electronics (like stepper motors, motor drivers, breakout board and spindle control?)
If you are going to use a FPGA IO card later, you might have to adapt its bitfile, but that's a more advanced topic.
My current cnc has 4 Stepper motors, 4 motors drivers, a C11G BOB (breakout board) and a ESS (Ethernet Smooth Stepper). I was referring to these electronics since I read somewhere that LinuxCNC uses different electronics.
This is my first time I use ESS and I have been not happy with it so when I switch to LinuxCNC I will not use the ESS, I will just plug a parallel cable from my BOB to the PC.
It is quite common/popular here in the community and recently supported in 2.8.4.
But if you want to stick to your BOB, you can replace your parallel port at some point by this card e.g.: store.mesanet.com/index.php?route=produc...ct_id=58&search=6i25
The Ethernet and Parallel port boards looks very interesting
