Python comp - Basic usage example
26 Jul 2023 16:58 - 26 Jul 2023 17:01 #276315
by zz912
Python comp - Basic usage example was created by zz912
Hello,
Here's something like "Hello world" for creating your own HAL component in Python:
linuxcnc.org/docs/2.9/html/hal/halmodule..._basic_usage_example
I think it would be good if there was a way to compile other than $PATH. I think many people don't know what $PATH is. Like me before.
forum.linuxcnc.org/38-general-linuxcnc-q...-path?start=0#274842
I suggest changing the text:
"Copy the above listing into a file named "passthrough", make it executable (chmod +x), and place it on your $PATH. Then try it out:"
to:
Second way copy the above listing into a file named "passthrough.py", run "sudo halcompile --install --userspace passthrough.py"
(Do not use [sudo] for RIP installation)
Then try it out:"
Or similar change text.
I think it could make it easier for many beginners to get into the HAL component in Python.
to:
Then try it out:"
Last edit: 26 Jul 2023 17:01 by zz912.
- AlexMagToast
- Thank you received: 66
28 Jul 2023 08:28 #276443
by AlexMagToast
Replied by AlexMagToast on topic Python comp - Basic usage example
I also had to learn what $Path is and only found out by lots of trying, so i agree with you.
After i sorted this out however i created a couple of python based components for my CNC Lathe all using this library:
linuxcnc.org/docs/html/hal/halmodule.html (it is the same i guess?)
To install you only have to do 2 steps:
1. make arduino.py executable with chmod +x, delete the suffix .py and copy it to /usr/bin
2. add this entry to the end of your hal file: loadusr arduino-connector
putting the files in /usr/bin works very well, for me. Isn't this always the right directory?
Here is a link to my repo, if anyone is interested. github.com/AlexmagToast
Said Components are: arduino_connector, Lubedude and Sauter Head Revolver.
sudo chmod +x arduino.py
sudo cp arduino-connector.py /usr/bin/arduino-connector
The following user(s) said Thank You: zz912, aaronstone
Moderators: HansU
Time to create page: 0.146 seconds
