Network in Arch linux
18 May 2022 17:34 #243286
by isaac85
Network in Arch linux was created by isaac85
Hello guys.
Sorry i cannot get solution to my problem.
I have all software ready in my arch linux, but i cannot connect my mesa board 7i95.
i configured:
/etc/systemd/network/20-wired.network
[Match]
Name=en*
[Network]
Address=10.10.10.255/24
Gateway=10.10.10.1
But it is not working.
When i do a ping 10.10.10.1 not work, i tried 10.10.10.10 too, and 192.168.1.121
What i am doing bad?
Someone can help to me?
Thank you.
i configured:
[Match]
Name=en*
[Network]
Gateway=10.10.10.1
Thank you.
- Thank you received: 5935
18 May 2022 18:16 #243289
It can be anything from 2 to 254, but NOT 10, and not 1 as it is used for gateways although it does work.
Replied by tommylight on topic Network in Arch linux
Address can not be 255.
[Network]
Gateway=10.10.10.1
19 May 2022 16:31 #243349
by isaac85
Replied by isaac85 on topic Network in Arch linux
Thank's for repy!
I Get a solution and i want share it because someone can need this help.
I am trying run my linuxcnc in archlinux with mesa 7i95 board.
for get my connection with mesa board:
I have installed NetworkManager and net-tools
~ sudo pacman -S networkmanager net-tools
next you can use nmcli for see the devices that you have and the status.
~ nmcli device
In my case it will show my device eno2, type ethernet, state connecting (not connected)
so for connect it i need configure the ip
~ ip address add 10.10.10.10/24 dev eno2
next you can execute a ping for see it work now.
~ ping 10.10.10.10
I hope it help someone!!
Hugs!
~ nmcli device
~ ping 10.10.10.10
Hugs!
20 May 2022 02:08 #243382
Replied by rodw on topic Network in Arch linux
Looks like you are pinging the interface on your PC, NOT the Mesa card. Read what Tommy said...
