Community Builder and Joomla Updates
18 Jun 2022 12:55 #245395
by BigJohnT
Community Builder and Joomla Updates was created by BigJohnT
I managed to update Community Builder and Joomla tot the latest version and did a test code post in off topic. The only snag now is you need to press the code button then paste your code in. And FINALLY you can edit your post without the code tags getting screwed up!
JT
JT
The following user(s) said Thank You: arvidb, tommylight
- Thank you received: 5934
18 Jun 2022 21:29 #245408
Replied by tommylight on topic Community Builder and Joomla Updates
Yayyyyyy!
Thank you.
Thank you.
19 Jun 2022 06:18 #245422
by arvidb
Replied by arvidb on topic Community Builder and Joomla Updates
Fantastic! Thanks!
19 Jun 2022 21:09 #245450
by BigJohnT
Replied by BigJohnT on topic Community Builder and Joomla Updates
The next task is to fix sendmail now that I know the forum uses that to send emails. I tested sendmail via the admin interface and it is not working. A chap on the IRC is pretty savvy with low level linux stuff so I'll have some help.
JT
JT
23 Jun 2022 17:13 #245703
by BigJohnT
Mail has been restored.
JT
JT
The following user(s) said Thank You: andypugh, tommylight
Time to create page: 0.155 seconds
