home hobbyist instructions
21 Oct 2022 04:17 #254646
by Boatssun
home hobbyist instructions was created by Boatssun
My name is David.
I just got a Genmitsu 3018-PRO. I have very little idea what to do.
Will someone tell me where in linuxcnc or on the internet where I can get starting instructions.
Side question, can I use my desktop or should I get a dedicated laptop?
Thank you for your help.
21 Oct 2022 08:03 #254651
by arvidb
Replied by arvidb on topic home hobbyist instructions
Starting instructions for what? What do you want to do?
21 Oct 2022 08:10 #254652
by HansU
Replied by HansU on topic home hobbyist instructions
I can only point you to the documentation: linuxcnc.org/docs/html/
As your machine has stepper motors I would suggest just start with linuxcnc.org/docs/html/config/stepconf.html
I would suggest using a desktop PC instead of a laptop. The power saving functions and shared memory of a laptop might not lead to the best performance and latency.
A desktop PC you also can expand easily with PCI/PCIe cards.
21 Oct 2022 12:32 #254671
(LinuxCNC is a CNC controller, not a way to drive other controllers from Linux)
Replied by andypugh on topic home hobbyist instructions
I think that this is supplied with a GRBL controller pre-installed? I don't think that you need LinuxCNC.I just got a Genmitsu 3018-PRO. I have very little idea what to do.
22 Oct 2022 13:47 #254756
by Boatssun
Replied by Boatssun on topic home hobbyist instructions
I am looking for instructions about turning a picture into a 2D or 3D carving.
I want to learn CAD/CAM program.
I am running Linux Mint.
22 Oct 2022 14:55 #254757
by arvidb
Well, there is a CAD/CAM subforum here so maybe you can get specific help with turning a picture into G-code for a carving there.
But LinuxCNC is an alternative to GRBL, so for instructions on how to control your machine, you are probably on the wrong forum. For figuring out what computer and OS you need to communicate with a GRBL controller you might want to turn somewhere else.
The following user(s) said Thank You: Boatssun
- Thank you received: 5945
22 Oct 2022 16:52 #254773
Replied by tommylight on topic home hobbyist instructions
LinuxCNC has "image 2 gcode" included for doing 3d carving from 2d pictures.
Personally, i use dmap2gcode it is free, also.
23 Oct 2022 05:26 #254826
by Boatssun
Last question. How do I close this thread?
Thank you for your help and guidance.
David
David
23 Oct 2022 10:30 #254842
by arvidb
I don't think there's any way to close a thread; also there's no need.
Good luck on your CNC adventures! (And if you want to convert your machine to LinuxCNC in the future, you are of course welcome back. )
Time to create page: 0.188 seconds
