New to EMC configuring limit switches
I am wondering how to set up the limit switches on my Knee mill that i plan to control using EMC2
I notice that in the pinouts EMC says limit/home for each axis. does this mean that one limit switch per axis is all that is required to operate the machine? Ie the machine will know which direction it was moving so it can alarm "over travel X positive" or similar. this is set up by positioning the limit centrally to the axis travel and having a ramp at each eng to trigger the switch...
does the machine then move toward X0 Y0 Z0 till it hits the limits and knows that it is home?
I am asking these questions as i need to know how many limit switches i will need to buy and wire up...
thanks
Andrew
The homing sequence is how you define it. Read about HOME_SEQUENCE here:
www.linuxcnc.org/docview/html//config_ini_homing.html
EMC2 doesn't require any limit or home switches. You can have any combination of limit/home switches. For EMC2 to know which limit has been tripped you need two switches for each axis, one for each direction limit. If you have enough inputs then a limit at each end and a home switch where ever you want it is nice to have. The best way to wire limit switches is for them to be normally closed so if you loose a wire the machine thinks it is on a limit instead of merrily crashing into the hard stop. Also position the limit switches so the axis will stop after tripping the limit before it hits the hard stop.
ok. thanks
I don't think i will have enough inputs on the breakout board to run that many switches... it has 5 inputs 6 would have been good:(
so can EMC recognize a second serial port with an additional breakout board to accommodate the desired inputs?
cheers
Andrew
The same can be done with the home switches.
EMC can recognize up to 8 Parallel ports (I assume that is what you meant not serial) though stepconf only helps with three.
stepconf also doesn't help you set up signals on the extra two parallel ports, you must do that in a custom file.
Are you using stepconf ? You can choose 'all limits' and connect all the limit switches in series, so would only use one parallel port input pin.
yes I'm assuming i mean parallel to;)
I haven't had much of a chance to muck around with it yet as the computer with the install isnt setup yet. i have just been having a bit of a look at the cd...
I have just been trying to work out what i should be buying to best get the job done. i have been buying almost everything via ebay from international sellers so need some planning so i dont get any unwanted delays...
can someone please explain how the homing sequence works with the home switches connected in series? how does it know if it has hit a switch?
thanks
Andrew
for the home switches i will use one per axis wired individually. this will leave 2 spare inputs in the breakout board. i will use one for the e-stop and the other is free at this stage.
are there any other required inputs that i am missing?
thanks again
Andrew
If your going to do a lot of setups a MPG is very handy. One with axis and increments selectors is even handier.
yes I have been wondering what is involved in setting one of these up?
was hoping to be able to make one... where does one plug such a device in? and is it feasible to make one?
cheers
Andy
I think it is time to boot up the computer that will run the show. stepper motors and drivers will arrive within 2 weeks and i am waiting for a quote to do the required machining on the ball screws. getting close (ish...)
Also look at wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Simple_Remote_Pendant and wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Add...imple_Remote_Pendant
Rick G
looks possible then but i might get the mill up and running first before i stick the time into this one...
