Index Homing odd offset
21 Oct 2015 06:21 #64023
Replied by andypugh on topic Index Homing odd offset
Can you zip up the config folder and attach it to a reply?
Also, if you compare your setup to the diagrams at www.linuxcnc.org/docs/html/config/ini-homing.html
which config type do you have, and what point does it break at?
21 Oct 2015 06:37 #64024
Replied by PCW on topic Index Homing odd offset
How are you driving you motors?
Can you post your hal and ini files?
AFAIK homing on index does _not_ work with step/direction unless setup properly
21 Oct 2015 07:36 #64025
by OT-CNC
Replied by OT-CNC on topic Index Homing odd offset
Andy,
I'm using the 2nd to last diagram homing routine. It fails right after receiving the assumed index signal. I will try to attach or post the ini and hal files.
21 Oct 2015 07:48 #64027
by OT-CNC
PCW,
Thanks for the info. I'm still on the same build, 2 axis lathe with DMM servo drives using your 7i85s 5i25 and field interface boards.
I have been running the drives step/dir for initial configurations to get things going but need to spend more time setting up for closed loop without joint following errors.
21 Oct 2015 07:51 #64028
To use homing on index you must set up the stepgen in velocity mode and use encoder
feedback to close the position loop
21 Oct 2015 16:18 #64035
Ah, yes. In open-loop step-dir LinuxCNC isn't even necessarily using the encoder feedback, is it?
You might expect following errors on index reset, though.
22 Oct 2015 06:03 - 22 Oct 2015 06:04 #64117
by OT-CNC
Here is the hal file.
Last edit: 22 Oct 2015 06:04 by OT-CNC.
22 Oct 2015 06:05 #64118
by OT-CNC
Here is the ini
22 Oct 2015 06:46 #64119
by OT-CNC
The 2 files are not final.
On this configuration, I get the joint following error when I double the default 60 ipm setting to 120. It faults out around 70-80 ipm On open loop 300 ipm no problem.
Let me know if there is anything obvious in there to correct that and get the index homing to work for starters.
I know it's off topic, but while you are looking at my hal file, on the wish list is a limit component to ignore the jog increments above .001" so my mpg only uses the jog increments that are selected below .001" for movement. I have not been able to figure that out after looking at the limit1.9 manual that Andy sent me a link to while ago.
Also, The spindle has not been implemented. I probably will need help with that as well. The spindle motor encoder is wired to the 7i85s, A,B and index and wiring the outputs to spinx next.
22 Oct 2015 07:37 - 22 Oct 2015 07:45 #64120
To try and solve the following in closed loop error issue I would first try setting
the tuning parameters a little differently:
Set P to 1000 (for X and Z in the INI file)
EDIT: gradually increase P up from 50 until you get oscillations and then back off to about 50% of the value that caused oscillation
(1000 is suited for open loop which means almost 0 delay from command to result,
closed loop will have more delay from step command to encoder count so cannot have as high a gain)
You can use the calibrate menu option to set the PID values live
Set pid.x.maxerror and pid.z.maxerror to .005 (these are in the hal file)
To run at 300 IPM you will of course need to set::
MAX_VELOCITY = 5.0
(5 IPS = 300 IPM)
STEPGEN_MAXVEL = 6.0
(25% headroom)
For both X and Z in the INI file
MAX_VELOCITY = 5.0
(5 IPS = 300 IPM)
(25% headroom)
Last edit: 22 Oct 2015 07:45 by PCW. Reason: forgot 1000 is for open loop
Time to create page: 0.259 seconds
