Matsuura Mc 500v2 retrofit.
- skunkworks
- Thank you received: 148
23 Feb 2016 16:54 #70526
by skunkworks
Matsuura Mc 500v2 retrofit. was created by skunkworks
We purchased this machine a couple years ago. It is an early 80's model with a mx1 control. The servo and spindle drives work just fine so we are planning on re-using everything that we can.
Going with mesa (of course)
We lucked out an all the axis encoders are 5v differential (some had 12v)
The setup is going to be
That will give me
-6 axis of analog out/differential encoders
-72 i/o
-panel interface MPG's and i/o
-expandable
Currently We just started and only have worked on getting a basic spindle encoder installed. It doesn't have one and we would like to be able to rigid tap.
We are using gear teeth sensors to do the quadature+index (they are not mounted yet)
This is a 69 tooth gear.
This will be slow going as I will only be able to work on it a few hours a week.
sam
computer -> Ethernet -> 7i80 -> 7i48
V
V -> 24 port opto22 board
V
V -> 7i44 -> 7i73
V
V -> 7i69 -> 2x 24 port opto22 boards
That will give me
-72 i/o
-expandable
sam
23 Feb 2016 22:48 - 23 Feb 2016 22:55 #70537
by BigJohnT
Replied by BigJohnT on topic Matsuura Mc 500v2 retrofit.
Nice gear install.
Are you using a 7I80HD-16?
Which Opto22 cards do you use?
JT
JT
Last edit: 23 Feb 2016 22:55 by BigJohnT.
24 Feb 2016 02:27 #70550
by timewarp
Replied by timewarp on topic Matsuura Mc 500v2 retrofit.
I would like to hear more about the opto 22 setup as well. Do you need the pci ac5 card? They are always pretty expensive on ebay,
Paul
Paul
- skunkworks
24 Feb 2016 02:38 - 24 Feb 2016 02:38 #70551
by skunkworks
Replied by skunkworks on topic Matsuura Mc 500v2 retrofit.
these style boards are a direct plugin to the mesa 50 pin connector.
www.ebay.com/itm/Opto-22-G4PB24-0055131D...e:g:yQUAAOSwKtlWqu6V
(really handy)
we used a combination of what we had on the K&T
electronicsam.com/images/KandT/conversio...el/electricalbox.jpg
(really handy)
Last edit: 24 Feb 2016 02:38 by skunkworks.
24 Feb 2016 03:17 #70553
by timewarp
- skunkworks
28 Feb 2016 23:25 #70779
by skunkworks
- skunkworks
02 Mar 2016 12:58 - 02 Mar 2016 13:10 #70901
by skunkworks
Last edit: 02 Mar 2016 13:10 by skunkworks.
- Thank you received: 1370
02 Mar 2016 13:44 #70906
Replied by Todd Zuercher on topic Matsuura Mc 500v2 retrofit.
Looks serviceable, well done!
- skunkworks
04 Apr 2016 18:21 #72733
by skunkworks
hooked the spindle encoder into the 7i48. seems to count and sees the index.
- skunkworks
06 Apr 2016 11:44 #72841
by skunkworks
Time to create page: 0.361 seconds
