Matsuura Mc 500v2 retrofit.
- skunkworks
- Thank you received: 153
13 May 2016 14:58 #74604
by skunkworks
Replied by skunkworks on topic Matsuura Mc 500v2 retrofit.
A brother label writer.. It isn't the best - The clear coat seems to like to peal off after a while. On the K&T we used electrical numbering stickers and then clear heat shrink over that. That worked the best IMHO.
sam
sam
- skunkworks
14 May 2016 01:22 #74633
by skunkworks
simple program with rigid tapping. (didn't have time to try it in metal)
- BigJohnT
- Thank you received: 994
14 May 2016 11:14 #74643
by BigJohnT
I use Brady heat shrink labels and they are permanent as I am.
JT
Replied by BigJohnT on topic Matsuura Mc 500v2 retrofit.
Hello,
What do you use to label your wires? It is retractable tube with printed labels? If so, how do you do it?
That machine is quite a good machine. Congratulations.
JT
- skunkworks
30 Jun 2016 00:53 #76815
by skunkworks
The spindle taper has 30 years of wear - a 6 inch tool was around .006" out. So - we didn't have much to lose
Now it is around .0005" at 6 inches.
(the dremel was the only thing that would fit up the BT35 taper) - that we had anyway
We also took added about .0015 shim between the 2 ball nuts on the Z axis.
electronicsam.com/images/matsuura/20160608_185327.jpg
Control panel
electronicsam.com/images/matsuura/20160622_153043.jpg
Control panel
- skunkworks
13 Jul 2016 13:02 #77391
by skunkworks
- BigJohnT
13 Jul 2016 13:04 #77392
by BigJohnT
Looking Good!
JT
JT
- eman5oh
- Thank you received: 11
30 Sep 2016 16:21 #81111
by eman5oh
Replied by eman5oh on topic Matsuura Mc 500v2 retrofit.
I see you did a spindle regrind, how did you align the Dremel to the taper?
- skunkworks
30 Sep 2016 17:47 - 30 Sep 2016 17:47 #81115
by skunkworks
really no alignment other than making sure it clears the whole way in.. The matsuura was doing the taper by moving z and y coordinated.
edit - after that we blued it to check fit. Looked good.
sam
sam
Last edit: 30 Sep 2016 17:47 by skunkworks.
- johnmc
16 Nov 2016 06:42 #82857
by johnmc
Replied by johnmc on topic Matsuura Mc 500v2 retrofit.
Good Day ,Sam
Your matsuura is looking neat, is the monitor a touch screen, where did you fit the pc ?, on the console is that a mpg for each axis?, has the Ethernet has been difficult to implement?. pardon the many
I have a matsuura with brain dead fanuc m6 control and your machine setup really looks the answer.
johnmc
johnmc
- chopper79
- Thank you received: 44
09 Jan 2017 05:41 #85500
by chopper79
Replied by chopper79 on topic Matsuura Mc 500v2 retrofit.
Nice job on the retrofit. I am going to begin mine in the next week or so. I have a 1982 MC-500v showing up Tuesday of this month. The MX1 controller will not function properly so retrofit it will be.
I will start a new thread, but wanted to let you know that I like what you have done.
Time to create page: 0.232 seconds
