How to setup a tool table correctly for manual tool change
19 Oct 2016 10:41 #81829
by Spectre
I am running V2.7.7 I have read a couple of wiki and also threads on here. I just spent a couple of hourse trying to get my tool heights set in the tool table. All referenced to a Haimer 3D sensor set to 0 on the vice edge as my G43. I have gone through all of my tools and set the heights and what comes up in the tool table list just does not make any sense. A lot of the documentation is old and does not seem to conform correctly to V2.7.7
Do anyone know of any documentation of how PRACTICALLY to do it step by step please
Mark
Mark
20 Oct 2016 17:33 #81893
Replied by andypugh on topic How to setup a tool table correctly for manual tool change
There are a number of ways to do it. This is what works for me.
My mill has a tighening/measuring station on the end of the table. I measure the tool lengths with a height gauge using this fixture.
This means that each tool length is measured from an almost-arbitrary point on the taper itself.
As long as I touch-off the work with the probe, and the probe-length is set correctly in the tool table, it all works.
I use the Touchy interface. This uses an obvious G10 in the MDI window for tool setting. But I have to edit that to enter an absolute tool length. (I need G10 L1 but the system defaults to G10 L10 with an option in settings to choose G10 L11)
You probably want G10 L11 and to set the G59.3 offsets to suit
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g10-l10
20 Oct 2016 21:46 #81905
by Spectre
Replied by Spectre on topic How to setup a tool table correctly for manual tool change
I posted this in another thread but videos on this subject for Lcnc are very scarce
24 Feb 2021 11:39 #199959
by Marsbar
Replied by Marsbar on topic How to setup a tool table correctly for manual tool change
I found the video thread that you (Spectre) posted really helpful. Thank you
Does anyone know how to change the tool table measurements to metric?
Everything is in imperial.
I have looked through Hal and Ini and the LCNC documentation but there doesn't seem to be anything I can change.
I am using Axis 2.7.14
24 Feb 2021 11:53 #199964
LinuxCNC is internally metric. Except for the Axis UI.
Look in the INI under [TRAJ]LINEAR_UNITS
]Does anyone know how to change the tool table measurements to metric?
Time to create page: 0.385 seconds
