Plasma Questions
29 Dec 2016 01:23 #84830
Replied by rodw on topic Plasma Questions
One other thought is that if the Ohmic sensor is shorted when entering the procedure, maybe it should attempt to move up to clear the error or a timeout occurs before throwing an error. If the short clears, reset the starting time and continue with probing.
29 Dec 2016 06:46 #84839
by Rick G
Replied by Rick G on topic Plasma Questions
Here is JT's touch off routine...
gnipsel.com/shop/plasma/files/touchoff.ngc
Rick G
o<touchoff> sub
(#1 pierce height, #2 pierce delay, #3 cut height)
F10
G38.2 Z-1.75 (Probe to find the surface)
G91
G1 Z0.070 (Raise up to Z0)
G90
G92 Z0 (Set Z0)
G1 Z#1
M3 S1
M66 P0 L1 Q5 (Wait for Arc OK from Torch)
G4 P#2 (Pause for pierce delay)
F25
Z#3 (goto cut height)
o<touchoff> endsub
M2
Rick G
- islander261
- Thank you received: 216
29 Dec 2016 19:36 #84868
by islander261
Replied by islander261 on topic Plasma Questions
Hello
Thank you for the responses.
Well I didn't explain things well enough. My new Z axis mechanics actually cause the float switch to be actuated just before (.2") the mechanical Z- stop. So I can use the float switch as a Z- limit switch if there is nothing under the torch. Actually one should have the torch either mechanically connected so that at the extreme Z- position the tip is not below the slats or grating on the table (helps to save on broken torch heads, don't ask me how I know this) or the Z- soft limits set to do the same thing. This is in combination with some kind of break away torch mount. My present stand alone THC requires that you mechanically set the torch up correctly in the mount because it doesn't have any Z- limits. Now I do have a question for the lcnc gurus, when the probing cycles are active (G38.X) are the soft and hard limits ignored? I can't find anything about this in the documentation. I think this is a problem unique to Mach 3.
I have been using conductive probing for several years now. I think I have a good handle on the failure modes. The most common failure I have is most likely unique to the Hypertherm Finecut consumables I use. The nozzle on the Finecuts is very exposed compared to the usual consumables. What happens is small piece of dross or slag gets caught between the nozzle and the shield shorting them together. This usually requires removing the shield to clean out the offending crude. The system response to a shorted contact sensor error at the beginning of the probe cycle should be to force the code execution to stop and the torch to raise to the Z home position (just below the Z+ soft limit) so it can be cleaned before resuming cutting. A much rarer error is water getting blown up into the space between the nozzle and shield. The anti corrosion water treatment makes it conductive enough to short the nozzle to the shield. This is much less of a problem because the post cutting cooling air flow usually cleans this out.
Now I am thinking that I want to use o subs to do my probing and torch firing unless there is better method. The best way I have found to use all the HAL pin values that get set from my modified Gmocappy Plasma GUI into my G code is to use this method:
linuxcnc.org/docs/devel/html/remap/remap...ap:referto-hal-items
If this isn't the correct method please point me to the right way. Along the same lines the only other way I can find to read and write to HAL pins is to use the M62-M65 digital I/O controls for bit types and M67 & M68 analog I/O controls for float types along with their associated motion.XXXXXX-XXX-XX HAL pins.
linuxcnc.org/docs/devel/html/gcode/m-code.html#mcode:m62-m65
linuxcnc.org/docs/devel/html/gcode/m-code.html#mcode:m67
I think these are also the same methods I need to use is I want to pass a value through the G code from my CAM SW (Sheetcam).
TIA
TIA
30 Dec 2016 06:58 - 30 Dec 2016 07:05 #84903
by Rick G
G38 can error if the probe is already in the target state. So if already triggered will not probe. You also set the maximum probe distance so you could set this to stay above the slats.
linuxcnc.org/docs/2.6/html/gcode/gcode.html#sec:G38-probe
I use a ngcgui sub to store all my cutting settings to numbered parameters that are saved in the parameter file, so they are easy to use in the torch light sub or g code where needed and as I do not use Gmocappy Plasma GUI so can't comment there.
forum.linuxcnc.org/plasma-subroutines-li...0376-plasma-settings
Rick G
No.when the probing cycles are active (G38.X) are the soft and hard limits ignored?
Rick G
Last edit: 30 Dec 2016 07:05 by Rick G.
- islander261
01 Jan 2017 01:16 - 01 Jan 2017 01:20 #84981
by islander261
Rick G
Thank you for the clarification. This makes things much easier.
Anyone
Now I have a new problem. I am trying to use parameters from the .ini and .hal files in o code subroutines. The instructions for accessing them are here:
linuxcnc.org/docs/devel/html/remap/remap...to-inifile-variables
My code looks like this:
My .ini file stanza looks like this:
My problem is that the o code subroutine can't find the .ini file parameter, all I get is the failure message. Where is my error in how I am trying to access these parameters? I haven't been able to test the parts the use parameters from the .hal files yet because they require working hardware (next few days). I think I am doing the correct thing by the docs. I am using 2.8.0-pre1-2771-gdc2ff49 and PREEMPT-RT.
TIA
Anyone
(compute Z axis W height)
o102 if[EXISTS[#<_ini[axis_z]min_limit>]]
(use z- limit as starting point)
#<w_height> = [#<_ini[axis_z]min_limit> + #<probe_dist> + 0.1000]
o102 else
(use safe starting place)
#<w_height> = [-2.900 + #<probe_dist>]
(MSG, Can't find Z MIN_Limit)
o102 endif
# Axis Z
[AXIS_Z]
MIN_LIMIT = -4.5
MAX_LIMIT = 0
MAX_VELOCITY = 3.83333333333
MAX_ACCELERATION = 37.1
TIA
Last edit: 01 Jan 2017 01:20 by islander261. Reason: Fix poor editting
01 Jan 2017 01:28 #84983
Replied by andypugh on topic Plasma Questions
Is it case-sensitive?
- islander261
01 Jan 2017 15:31 #85016
by islander261
Hello
The documents say that the interpreter converts all chars to upper case. I have tried both cases with the same results.I was just trying to keep like source parameters together. Machine hardware related parameters coming from the .ini, GUI related parameters coming from the .hal files and the part related parameters coming in on the G code file.
01 Jan 2017 16:41 #85019
Have you set the feature mask to allow INI access?
- islander261
01 Jan 2017 18:36 #85031
by islander261
Andy
Thank you, my bad for not reading the entire instructions. Having the FEATURES = 12 in my .ini file fixed this.
04 Jan 2017 06:03 #85184
by grijalvap
Replied by grijalvap on topic Plasma Questions
hi do you think it is possible to make a THC using the analog to digital card from mesa
store.mesanet.com/index.php?route=produc...83_88&product_id=126
can it be more accurate?
