need help to make a pcb with out erros
19 Jan 2017 22:01 #86200
by simon c
need help to make a pcb with out erros was created by simon c
- Thank you received: 5935
19 Jan 2017 22:14 #86201
Replied by tommylight on topic need help to make a pcb with out erros
It shure looks like too much flex in the machine and some missed steps.
Can you post pictures of the machine?
- Thank you received: 1369
19 Jan 2017 22:15 - 19 Jan 2017 22:18 #86202
Replied by Todd Zuercher on topic need help to make a pcb with out erros
Without more information, it looks like probably a combination of lost steps and maybe some backlash problems.
(too hi acceleration + backlash compensation will often give results just like these.)
Last edit: 19 Jan 2017 22:18 by Todd Zuercher.
19 Jan 2017 22:32 #86203
by simon c
Replied by simon c on topic need help to make a pcb with out erros
19 Jan 2017 22:37 #86204
by simon c
I run with these settings in linuxcnc lavalu.de/EMC_Wizard.html
19 Jan 2017 22:47 #86205
That is a Proxon MF70 right? it should be good for engraving as it is quite a sturdy machine.
The link you pested is to old so start here,
wiki.linuxcnc.org/cgi-bin/wiki.pl
Also check for anything loose on the machine.
19 Jan 2017 22:49 #86206
by bogie6040
Replied by bogie6040 on topic need help to make a pcb with out erros
I would start by putting a dial indicator on your table and push up against the non running spindle. Do some tests to make sure that a commanded 1/2 an inch or 10 MM axis move is really what it is doing, first at slow speeds then at the maximum it is setup for. If it can't pass these tests you will never get acceptable results from it.
20 Jan 2017 01:31 #86219
by Sparky961
Replied by Sparky961 on topic need help to make a pcb with out erros
Adding to what others have suggested, you'll also want to set up your strap clamps differently. If it isn't already, you're just asking for your material to move on you the way you have it clamped now.
This video shows some of the basics for clamping:
21 Jan 2017 11:38 #86349
by simon c
21 Jan 2017 21:42 - 21 Jan 2017 21:45 #86382
by bevins
Replied by bevins on topic need help to make a pcb with out erros
Looks like backlash to me.
Show some pics of your machine and the drive trains...... ballscrew, rack and pinion or whatever you use.
Its pretty much symetrical in the way it is cutting, does the same oval everytime and the spacing looks right, so something in your drivetrain is out.
Just my 2 cents.
Bob
Just my 2 cents.
Bob
Last edit: 21 Jan 2017 21:45 by bevins.
Time to create page: 0.097 seconds
