Native cam help with ini.file/ subroutine_path
29 Jan 2017 22:01 #86931 by Dougefresh
I'm having a noob issue with controlling my cnc once native cam is intergrated. I can control my cnc from my original configuration file but when I try with native cam I cannot.
29 Jan 2017 22:21 #86932 by Dougefresh
I'm thinking I have to copy over the ini. File from native cam to my original ini.file?
30 Jan 2017 03:40 #86940 by cncnoob1979
What linuxcnc version are you running?
Can you post your ini file?
30 Jan 2017 03:54 - 30 Jan 2017 04:06 #86941 by Dougefresh
Last edit: 30 Jan 2017 04:06 by Dougefresh.
30 Jan 2017 15:21 - 30 Jan 2017 15:22 #86973 by cncnoob1979
Here is the readme of Ncam;
github.com/FernV/NativeCAM
go into terminal and issue this command from your home folder:
git clone https://github.com/FernV/NativeCAM ncam
When complete you will have a new folder named ncam in your home directory. Enter the directory and follow the read me for imbedded ncam into axis.
In your ini you have to edit your display section and also your paths sections. The relative bits are in asterisks in the sim .ini I copied and pasted here.
Warning: Spoiler!
Warning: Spoiler!
Last edit: 30 Jan 2017 15:22 by cncnoob1979.
30 Jan 2017 18:22 #86986 by Dougefresh
Thanks cncnoob. I will try again tonight. Im still a little confused on how to modify the subroutine path. So you just copy the files from the native cam ini. To your my-mill ini. Created by linux cnc?
30 Jan 2017 18:27 #86987 by Dougefresh
Maybe seeing your modified ini. File would help me to better understand.
30 Jan 2017 22:19 - 30 Jan 2017 22:21 #87010 by cncnoob1979
Here is my ini for axis. Look for my path's and how they are modified from yours. Be sure to follow the readme I linked. The display section is where you really need for ncam to embed into axis.
File Name: bridgeport...1-30.ini
File Size:8 KB
You must edit your ini file to reflect these changes. The ini that your machine uses to load linuxcnc.
Last edit: 30 Jan 2017 22:21 by cncnoob1979.
The following user(s) said Thank You: Dougefresh
31 Jan 2017 02:23 - 31 Jan 2017 02:29 #87031 by Dougefresh
I finally got ncam to load embedded when I start linux cnc. Im getting an g-code error when I try to load a work peice. Im positive I dont have a file in the right place...
Last edit: 31 Jan 2017 02:29 by Dougefresh.
31 Jan 2017 02:25 #87032 by cncnoob1979
Sounds like you don't have the paths correct for where ncam is located.
Send me an email and I'll respond with my number. I'll walk you through it.
Time to create page: 0.225 seconds
