Calibration tab in axis GUI
07 Mar 2017 03:20 #89122
by JR1050
Calibration tab in axis GUI was created by JR1050
A while ago I upgraded from 2.4 to the present release of 2.6. When I open up calibration tab( for pid tuning) , the box opens but there are no fields , big gray box with apply and quit on the bottom. Any ideas what might cause this?
- Thank you received: 1369
07 Mar 2017 04:12 #89123
Replied by Todd Zuercher on topic Calibration tab in axis GUI
What does your ini file look like? The settings that are inserted into the tuning menu are pulled from the ini file.
- Thank you received: 5928
07 Mar 2017 18:17 #89144
Replied by tommylight on topic Calibration tab in axis GUI
Sidenote: that menu is for servo calibration, for steppers i do not know if it does anything.
04 Aug 2018 13:32 #115603
by JR1050
Replied by JR1050 on topic Calibration tab in axis GUI
It took me a while to get back to this. Attached are the
.ini and hal files. Im having the same issue on another machine with
ver 2.5.1. Both machines initially started with with imported hal/ini files from ver 2.4.3. Thanks as always
Time to create page: 0.185 seconds
