Toolchanger
- Nondepietjes
25 Apr 2017 08:44 #92037
by Nondepietjes
Toolchanger was created by Nondepietjes
I'm doing a retrofit of a lathe CNC machine and i'm using a 7i77 mesa card.
now my problem is that i have a toolturrent. everything of the machine is done exept this.
has anybody an idea how to program this?
Many thanks
Many thanks
- Thank you received: 4646
25 Apr 2017 16:44 #92078
Replied by andypugh on topic Toolchanger
Hmm, quite a sequence there.
You will need to program something to handle the same sequence of operations. The sequence could be written in Classic Ladder, G-code or C. Are you familiar with any of those?
- Nondepietjes
26 Apr 2017 06:08 - 26 Apr 2017 06:38 #92119
by Nondepietjes
Replied by Nondepietjes on topic Toolchanger
I'm familiar with Classic ladder, but i think not enough.
i have 3 outputs:
CW and CCW turning of motor and one for the elektromagnet
than i have 5 inputs of the encoder: bit1, bit2, bit3, bit 4 and the strobe.
than two inputs for two sensors.
and I want to connect every tool with a button.
Between the red lines is one sequence, the toolturrent rotats than one position.
how do i start on this, or is there not enough information?
i have 3 outputs:
Last edit: 26 Apr 2017 06:38 by Nondepietjes.
26 Apr 2017 15:05 - 26 Apr 2017 15:06 #92152
The tool numbers are straight binary with a strobe bit.
I don't know enough about Ladder to advise on it.
If I was doing it I would use a G-code routine to handle the unlock-move-unlock sequence and the carousel HAL component to choose motion directions and to interpret the sensors.
Last edit: 26 Apr 2017 15:06 by andypugh.
- Nondepietjes
27 Apr 2017 06:12 #92180
by Nondepietjes
And do you mayby have any examples of this? i think i'm going to try whit G-code
27 Apr 2017 08:13 #92184
There is a sample config that does this, sim/axis/vismach/vmc_toolchanger
Look at the two python files (you can probably use them unmodified) and the REMAP= in the INI file. The .ngc routine runs a sequence of digital outputs and waiting for digital inputs. Note the timeout handling...
You might also want to look a the sim/axis/lathe_fanucy config, that uses a slightly different remap to give lathe-style toolchanges (T-word only) with separate wear-offsets.
