are non cuboid soft limits possible?
- mechatroptik rainer
22 Jun 2017 17:55 #94795
by mechatroptik rainer
are non cuboid soft limits possible? was created by mechatroptik rainer
There are two obstacles in my gantrymachine that I want to avoid to crash by some soft limit. This can't be done by using just min /max values of each individual axis in the ini-File. The forbidden space can be describe in the form "if Z is more than 123 then Y is not allowed to be less than 456"
Is there a way to do that?
Thank you in advance.
Regards
Rainer
Regards
Rainer
- Thank you received: 1471
22 Jun 2017 18:12 #94797
Replied by Todd Zuercher on topic are non cuboid soft limits possible?
No, there is no provision for this in Linuxcnc. But that does not mean that it can't be done. I think that with some clever hal coding you could restrict movement to that area, but there still will be no pre-checking of moves (such as the warning you get when you load a file that exceeds a soft limit.)
The following user(s) said Thank You: mechatroptik rainer
22 Jun 2017 19:07 #94799
Something like this:This is only an example piece of code, it will need to be modified to fit in with your existing hal file.
loadrt comp count=2
loadrt and2 count=1
loadrt message names=restricted.0 messages=Movement Restricted
addf comp.0 servo-thread
addf comp.1 servo-thread
addf and2.0 servo-thread
addf restricted.0 servo-thread
setp comp.0.in0 123
setp comp.1.in0 456
net z-rest <=comp.0.out => and2.0.in0
net y-rest <=comp.1.out => and2.0.in1
net z-pos <= axis.2.joint-pos-cmd => comp.0.in1
net y-pos <= axis.1.joint-pos-cmd => comp.1.in1
net restrict <= and2.0.out => restricted.0.trigger => motion.feed-inhibit
- Thank you received: 4648
22 Jun 2017 20:24 #94806
Replied by andypugh on topic are non cuboid soft limits possible?
It _might_ work to restrict the joints as well as the axes, if it is the machine geometry that is the problem.
Otherwise some sort of HAL component to set feed-inhibit when outside the allowed polyhedron might work.
I have long thought that the axis limits should be optionally defined by an STL file.
22 Jun 2017 22:36 #94812
Replied by mechatroptik rainer on topic are non cuboid soft limits possible?
Thank you!
I'll Try Todds Idea.
Andy, I'm not sure if I understood you correctly. Machine geometrie is the problem in a ceratin sense. It's a gantry machine with trivial kinematics. But Y-Axis has additional contraints below a certain height.
Could that be solved by some trick in the kinematic description
Limits by STL would be great. I'm not sure how many ppl would actually use this.
Is it possible to draw additional lines in the axis 3D view? Like the wire-cuboid that visualizes machine limits.
Regards
Rainer
Regards
Rainer
23 Jun 2017 12:47 #94833
In that case joint contstraints won't work.
If you consider something like a delta robot the working volume is a wierd shape in XYZ space, but is a simple max and min limit for each joint.
25 Jun 2017 18:53 #94938
it works!
My movement below a Z-Height of 129.7 mm is restricted to a Y-range between 24.9 mm and 473.7 mm
Here is the tested code.
Thank you again!
Rainer
it works!
Thank you again!
Rainer
loadrt comp count=3
loadrt and2 count=2
loadrt or2 count=1
loadrt message names=restricted.0 messages="Movement Restricted"
addf comp.2 servo-thread
addf and2.1 servo-thread
addf or2.0 servo-thread
setp comp.0.in1 129.7
setp comp.1.in1 24.9
setp comp.2.in0 473.7
net z-pos <= axis.2.joint-pos-cmd => comp.0.in0
net y-pos <= axis.1.joint-pos-cmd => comp.1.in0 => comp.2.in1
net z-rest <= comp.0.out => and2.0.in0 => and2.1.in0
net y-rest <= comp.1.out => and2.0.in1
net y-rest2 <= comp.2.out => and2.1.in1
net rest-ymin and2.0.out => or2.0.in1
net rest-ymax and2.1.out => or2.0.in0
net restrict <= or2.0.out => restricted.0.trigger => motion.feed-inhibit
The following user(s) said Thank You: Todd Zuercher, tommylight
25 Jun 2017 21:10 #94945
Thanks for posting your successful code for others to see.
Time to create page: 0.253 seconds
