Linux Ubuntu and mesa7176E
- cintsa cnc
05 Jul 2017 15:40 #95396
by cintsa cnc
Linux Ubuntu and mesa7176E was created by cintsa cnc
I have Linux cnc running on Ubuntu kernal on an old machine which also runs Windows XP. I have recently purchase a MESA 7176E module and stepper drivers. My question is can I remove XP and install the DEbian based Linux CNC on the is machine to enable me to use the ethernet connection of the 7176E without interfering with the Ubuntu version.?
- Online
- Thank you received: 1369
05 Jul 2017 16:55 #95401
Replied by Todd Zuercher on topic Linux Ubuntu and mesa7176E
You can.
Remember, the Mesa Ethernet cards require a different real time kernel than the standard RTAI one that is on the Linuxcnc iso. It is much easier to setup and patch these Preempt-rt kernels and therefore not so tied to specific distributions as the RTAI one. You can use just about use what ever Linux distro you desire with Preempt-rt. (Mint, Ubuntu, Debian...) But life might be simplest if you choose one that has a buildbot version of Linuxcnc available..
- cintsa cnc
05 Jul 2017 18:57 #95409
by cintsa cnc
Replied by cintsa cnc on topic Linux Ubuntu and mesa7176E
Thank you for your reply. Being a retired machinist very new to the computer world, I am not sure I understand "patch these Preempt-rt kernels". Can you advise which of the packages has a BUILDBOT version.
- Online
05 Jul 2017 19:36 #95412
Buildbot is a Linuxcnc repository where new pre-compiled versions of Linuxcnc are stored.
buildbot.linuxcnc.org/
Take a good look at the installation instructions in the Linuxcnc documentation. It is explained fairly well there. (I have been using Linuxcnc for 7 years and I have never tried to patch my own real time kernel yet. So don't worry to much about it.)
linuxcnc.org/docs/devel/html/getting-sta...th_preempt_rt_kernel
There are currently Preempt-rt kernels avalible from Debian directly for Debian 7 (Wheezy), 8 (Jessie), and 9 (Stretch). That could be installed using the above instructions (with minor variation for the distro version you choose)
And Linuxcnc buildbot has precompiled versions of Linuxcnc for each of those.
(These precompiled Preempt-rt kennels do not always seem to be available. They seem to have a tendency to pop up for a few months then disappear for a while. (Has something to do with new kernel releases.)
The following user(s) said Thank You: cintsa cnc
- eFalegname
- Thank you received: 30
06 Jul 2017 08:03 #95425
by eFalegname
Replied by eFalegname on topic Linux Ubuntu and mesa7176E
You can install Linuxcnc from the new iso-livecd with the released version 2.9 and the Preempt-rt kernel (not RTAI):
www.linuxcnc.org/testing-stretch-amd64-rtpreempt/
Floris
Floris
Time to create page: 0.120 seconds
