Shared Home Switch is Closed
08 Jul 2017 20:09 #95513
Replied by rodw on topic Shared Home Switch is Closed
I think it means you have not touched off in the sim. Jog the Z down a bit and touch off in the axis GUI. This is mentioned in the docs somewhere.
I'm not sure about the error for the Y axis though. I have the same fault in a working machine in one test file. I'm going to try editing the file to use relative coordinates and jog away from the edge before running the part. But you should not need to do that in the sim.
14 Sep 2017 17:43 - 14 Sep 2017 18:58 #98957
by scubawarm
Replied by scubawarm on topic Shared Home Switch is Closed
I am struggling with this myself with all of the gmoccapy screens.
Note: Using DEV systems.
Hard to do anything when you can't home it.
I think I found an error in the simulator-gantry-home.hal, but there still seem to be issues further up the food chain as well.
Last edit: 14 Sep 2017 18:58 by scubawarm.
14 Sep 2017 20:29 #98969
Scubawarm, try the gmocappy plasma sim. I have found a few bugs in it that which Norbert has fixed.
If not, I would start my playing in the default axis GUI as its the gold standard.... It easy to change to gmoccappy down the track just by changing a few variables in the ini file
Time to create page: 0.179 seconds
