Machine won't jog or run a program
- cintsa cnc
06 Nov 2017 12:50 #101418
by cintsa cnc
Replied by cintsa cnc on topic Machine won't jog or run a program
I am not sure this is the right place for my problem but it is similar. i am using "AXIS" . Everything was working fine until I ran the config. wizard to improve the accuracy of the X and Y axis. Now I am able to load a program as usual but when I hit the run button, the controls dull out as usual but the program will not run. when the stop button is pressed all the controls come back to normal.
I am able to manually jog the three axis as well as use MIDI commands to move the axis I tried resetting the config file back to what t was but the problem still exists. The machine will run the start up program LINUX CNC engrave.
I have attache d the Ini. and Hal. files in case there is something I have missed
06 Nov 2017 13:59 #101423
Replied by andypugh on topic Machine won't jog or run a program
This sounds like a feed-override or spindle-at-speed problem.
Possibly the sample code sets over-ride on these:
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m48-m49
Alternatively, perhaps the sample code does not select a tool, and your code does, but the tool-change loop is not configured.
To test this second theory, hat happens if you enter T1 M6 in the MDI window?
- cintsa cnc
07 Nov 2017 06:48 #101483
by cintsa cnc
No reaction to T1 M6
is there any way to repair AXIS without reloading the whole Debian package?
07 Nov 2017 13:57 #101491
Check the HAL file for iocontrol.0.tool-change and iocontrol.0.tool-prepare.
Wshere do they link to?
- cintsa cnc
07 Nov 2017 15:55 #101494
by cintsa cnc
Will only get back to machine early tomorrow morning your time. Will reply soonest
- cintsa cnc
11 Nov 2017 07:46 #101642
by cintsa cnc
I have been without internet for a few days. I finally re loaded the Linux package and now everything appears to be working fine. Thanks for your assistance and time.
Time to create page: 0.221 seconds
