Morbidelli retrofit with Vickers drives and DC servos
29 Jul 2019 16:18 #140891
by Rapmac
Replied by Rapmac on topic Morbidelli retrofit with Vickers drives and DC servos
Have you had any success with some of the connections between 7i77 and Vickers AZE-CC4Q drives? Any help will be much appreciated.
01 Jan 2021 17:32 - 01 Jan 2021 17:44 #193744
by bobi92
Replied by bobi92 on topic Morbidelli retrofit with Vickers drives and DC servos
for my newest project i am looking for informations.
In my workshop i had an old bridgeport series 1 (milling machine), the problem is that you can only drive one servo at the same time.
The aim of this project should be to move all three axes simultaneously.
By chance I got a power amplifier from the brand el.ge / vickers aze now I want to wire it up. However, I do not fully understand which terminal must be connected to which signal.
Since the project mentioned here was a few years ago, I assume that this has been completed. Is it possible to get a circuit diagram on which you can see the correct wiring ?
regards Marco
regards Marco
Last edit: 01 Jan 2021 17:44 by bobi92.
01 Jan 2021 17:38 - 01 Jan 2021 17:41 #193745
by bobi92
Regards from Germany !!!
Last edit: 01 Jan 2021 17:41 by bobi92.
02 Jan 2022 18:45 #230564
by mazmazik
Replied by mazmazik on topic Morbidelli retrofit with Vickers drives and DC servos
Hello everyone!!
Has someone managed with 7i77 and Vickers AZE-CC4Q? I have Morbidelli U46, week ago fault signals on all three servodrivers lighted; original TRIA software is completely outdated - perhaps better solution would be to retrofit than repair this old system.
regards from Poland
Marek
regards from Poland
Marek
Time to create page: 0.500 seconds
