next tool - need an integer available to my custom M code
05 Sep 2017 18:52 #98541
by docslip
next tool - need an integer available to my custom M code was created by docslip
My linuxcnc system works well and I've been a user since 2004. I do have a problem and have , thus far, been unable to solve.
I have written a bash script and called it M102. It fires up great but the argument I pass is not the next tool , from Tn, awaiting the m6.
I want to have the tool next value to index a list of photos which I will display on the monitor. All that is easy stuff but I cannot seem to get the iocontrol.0.tool-number into my axis environment. Global variable needed ?
Can you more experienced fellows help me ?
Bill Phillips
Thank you
Bill Phillips
Thank you
05 Sep 2017 19:58 #98543
by bevins
Replied by bevins on topic next tool - need an integer available to my custom M code
selectedtool has the tool number.
- Thank you received: 1369
05 Sep 2017 20:25 #98544
Replied by Todd Zuercher on topic next tool - need an integer available to my custom M code
#<_selected_tool> is the global parameter for the selected tool (tool called before M6 is executed.)
#<_current_tool> is the global parameter for the current tool in the spindle (after M6)
The hal pins iocontrol.0.tool-prep-number and iocontrol.0.tool-number should should give the same values. (Although I think iocontrol.0.tool-prep-number is changed to 0 after an M6 until a Tn code is used.)
05 Sep 2017 20:29 #98546
by docslip
Replied by docslip on topic next tool - need an integer available to my custom M code
Thank you sir, but same result..My MDI command exactly is M102 P#<selectedtool> and every other conceivable way I can embrace the variables name: including M102 P#<_selectedname>. I've been failing at this ,otherwise simple op for 3 days, almost forgetting the goal.
ideas in the syntax required ?
05 Sep 2017 20:35 #98547
by docslip
It works as expected, thank you. Of all that I have read not once was that global name discovered. Tell me young man, where should I have looked.
Thanks again.
Bill Phillips
Thanks again.
Bill Phillips
06 Sep 2017 00:58 #98564
Right here.
linuxcnc.org/docs/html/gcode/overview.ht...ub:system-parameters
Thanks again.
Bill Phillips
Right here.
The following user(s) said Thank You: docslip
06 Sep 2017 01:27 #98565
by docslip
Oh, I feel like such a stoop. I recall that page from years ago. Getting old is not for sissies.
Thanks again.
Thanks again.
Time to create page: 0.072 seconds
