LinuxCNC terminated with error
15 Sep 2017 19:16 #99005
by Moptop
LinuxCNC terminated with error was created by Moptop
Got this error message which means nothing to me but it locks me out of the progam.
Trying to convert from Mach3 to LinuxCNC does not bode very well at the moment,
all this scripty stuff is the last thing I need. At the moment not very impressed at all
but will try again when I can get into the program again
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.11
Machine configuration directory is '/home/maurice/linuxcnc/configs/Router'
Machine configuration file is 'Router.ini'
INIFILE=/home/maurice/linuxcnc/configs/Router/Router.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Router.hal
Killing task linuxcncsvr, PID=4574
Debug file information:
sim_hardware.hal:35: parameter or pin 'parport.0.pin-02-out-invert-fake' not found
4574
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
[ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003fee0000 (usable)
[ 0.000000] BIOS-e820: 000000003fee0000 - 000000003fee3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003fee3000 - 000000003fef0000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003fef0000 - 000000003ff00000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: MEDIONPC MS-7204/MS-7204, BIOS 6.00 PG 10/07/2005
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3fee0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03FF00000 mask FFFF00000 write-through
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f4f20] f4f20
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 363f0000 - 371f0000
[ 0.000000] ACPI: RSDP 000f8dd0 00014 (v00 IntelR)
[ 0.000000] ACPI: RSDT 3fee3040 00038 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 3fee30c0 00074 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 3fee3180 0488F (v01 INTELR AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 3fee0000 00040
[ 0.000000] ACPI: MCFG 3fee7b80 0003C (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC 3fee7a80 00084 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: SSDT 3fee7c00 0015C (v01 PmRef Cpu0Ist 00003000 INTL 20041203)
[ 0.000000] ACPI: SSDT 3fee8090 0022A (v01 PmRef CpuPm 00003000 INTL 20041203)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 134MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003fee0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003fee0
[ 0.000000] On node 0 totalpages: 261743
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5bf0200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 270 pages used for memmap
[ 0.000000] HighMem zone: 34260 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 3ff00000 (gap: 3ff00000:a0100000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77b2000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259697
[ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-3.4-9-rtai-686-pae root=/dev/mapper/LinuxCNC2-root ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2094720 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003fee0)
[ 0.000000] Memory: 1015432k/1047424k available (3495k kernel code, 31540k reserved, 1237k data, 416k init, 138120k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f5408000 soft=f540a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2999.629 MHz processor.
[ 0.008004] Calibrating delay loop (skipped), value calculated using timer frequency.. 5999.25 BogoMIPS (lpj=11998516)
[ 0.008011] pid_max: default: 32768 minimum: 301
[ 0.008087] Security Framework initialized
[ 0.008094] AppArmor: AppArmor disabled by boot time parameter
[ 0.008127] Mount-cache hash table entries: 512
[ 0.008428] Initializing cgroup subsys cpuacct
[ 0.008433] Initializing cgroup subsys memory
[ 0.008448] Initializing cgroup subsys devices
[ 0.008452] Initializing cgroup subsys freezer
[ 0.008456] Initializing cgroup subsys net_cls
[ 0.008459] Initializing cgroup subsys blkio
[ 0.008472] Initializing cgroup subsys perf_event
[ 0.008524] CPU: Physical Processor ID: 0
[ 0.008527] CPU: Processor Core ID: 0
[ 0.008532] mce: CPU supports 4 MCE banks
[ 0.008545] CPU0: Thermal monitoring enabled (TM1)
[ 0.008629] ACPI: Core revision 20120320
[ 0.020104] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.020498] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.060371] CPU0: Intel(R) Pentium(R) D CPU 3.00GHz stepping 04
[ 0.064003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.064003] ... version: 0
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 18
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 0000007fffffffff
[ 0.064003] ... fixed-purpose events: 0
[ 0.064003] ... event mask: 000000000003ffff
[ 0.072035] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.084040] CPU 1 irqstacks, hard=f549a000 soft=f549c000
[ 0.084045] Booting Node 0, Processors #1
[ 0.012000] Initializing CPU#1
[ 0.096038] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.096099] Brought up 2 CPUs
[ 0.096105] Total of 2 processors activated (11998.51 BogoMIPS).
[ 0.097076] devtmpfs: initialized
[ 0.097076] PM: Registering ACPI NVS region [mem 0x3fee0000-0x3fee2fff] (12288 bytes)
[ 0.097076] dummy:
[ 0.097076] NET: Registered protocol family 16
[ 0.097076] ACPI: bus type pci registered
[ 0.097076] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.097076] PCI: Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub with MMCONFIG support
[ 0.097076] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.097076] PCI: Using MMCONFIG for extended config space
[ 0.097076] PCI: Using configuration type 1 for base access
[ 0.097076] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.097076] mtrr: probably your BIOS does not setup all CPUs.
[ 0.097076] mtrr: corrected configuration.
[ 0.100504] bio: create slab <bio-0> at 0
[ 0.100504] ACPI: Added _OSI(Module Device)
[ 0.100504] ACPI: Added _OSI(Processor Device)
[ 0.100504] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.100504] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.102595] ACPI: EC: Look up EC in DSDT
[ 0.113194] ACPI: SSDT 3fee8000 00087 (v01 PmRef Cpu1Ist 00003000 INTL 20041203)
[ 0.113830] ACPI: Dynamic OEM Table Load:
[ 0.113838] ACPI: SSDT (null) 00087 (v01 PmRef Cpu1Ist 00003000 INTL 20041203)
[ 0.114244] ACPI: Interpreter enabled
[ 0.114262] ACPI: (supports S0 S3 S4 S5)
[ 0.114313] ACPI: Using IOAPIC for interrupt routing
[ 0.124210] ACPI: No dock devices found.
[ 0.124223] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.124349] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.124545] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.124550] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.124555] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.124560] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.124565] pci_root PNP0A08:00: host bridge window [mem 0x3ff00000-0xfebfffff] (ignored)
[ 0.124570] PCI: root bus 00: using default resources
[ 0.124637] PCI host bridge to bus 0000:00
[ 0.124643] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.124647] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.124665] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[ 0.124741] pci 0000:00:01.0: [8086:2771] type 01 class 0x060400
[ 0.124802] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.124873] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.124897] pci 0000:00:1b.0: reg 10: [mem 0xfdff8000-0xfdffbfff 64bit]
[ 0.124977] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.125011] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.125069] pci 0000:00:1d.0: reg 20: [io 0xff00-0xff1f]
[ 0.125113] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.125170] pci 0000:00:1d.1: reg 20: [io 0xfe00-0xfe1f]
[ 0.125215] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.125272] pci 0000:00:1d.2: reg 20: [io 0xfd00-0xfd1f]
[ 0.125315] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.125372] pci 0000:00:1d.3: reg 20: [io 0xfc00-0xfc1f]
[ 0.125426] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.125451] pci 0000:00:1d.7: reg 10: [mem 0xfdfff000-0xfdfff3ff]
[ 0.125541] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.125567] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.125652] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.125766] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.125782] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0800 (mask 003f)
[ 0.125789] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 001f)
[ 0.125834] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.125854] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.125869] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.125883] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007]
[ 0.125897] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003]
[ 0.125912] pci 0000:00:1f.1: reg 20: [io 0xfb00-0xfb0f]
[ 0.125963] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.125985] pci 0000:00:1f.2: reg 10: [io 0xfa00-0xfa07]
[ 0.125999] pci 0000:00:1f.2: reg 14: [io 0xf900-0xf903]
[ 0.126012] pci 0000:00:1f.2: reg 18: [io 0xf800-0xf807]
[ 0.126024] pci 0000:00:1f.2: reg 1c: [io 0xf700-0xf703]
[ 0.126037] pci 0000:00:1f.2: reg 20: [io 0xf600-0xf60f]
[ 0.126080] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.126103] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.126171] pci 0000:00:1f.3: reg 20: [io 0x0500-0x051f]
[ 0.126284] pci 0000:01:00.0: [10de:0147] type 00 class 0x030000
[ 0.126302] pci 0000:01:00.0: reg 10: [mem 0xf4000000-0xf7ffffff]
[ 0.126320] pci 0000:01:00.0: reg 14: [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.126337] pci 0000:01:00.0: reg 1c: [mem 0xfa000000-0xfaffffff 64bit]
[ 0.126358] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[ 0.126407] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.126421] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.126427] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.126433] pci 0000:00:01.0: bridge window [mem 0xf4000000-0xfbffffff]
[ 0.126442] pci 0000:00:01.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.126493] pci 0000:02:02.0: [10ec:8139] type 00 class 0x020000
[ 0.126518] pci 0000:02:02.0: reg 10: [io 0xec00-0xecff]
[ 0.126533] pci 0000:02:02.0: reg 14: [mem 0xfdeff000-0xfdeff0ff]
[ 0.126592] pci 0000:02:02.0: reg 30: [mem 0x00000000-0x0000ffff pref]
[ 0.126620] pci 0000:02:02.0: supports D1 D2
[ 0.126624] pci 0000:02:02.0: PME# supported from D1 D2 D3hot D3cold
[ 0.126655] pci 0000:02:03.0: [1106:3044] type 00 class 0x0c0010
[ 0.126681] pci 0000:02:03.0: reg 10: [mem 0xfdefe000-0xfdefe7ff]
[ 0.126696] pci 0000:02:03.0: reg 14: [io 0xef00-0xef7f]
[ 0.126779] pci 0000:02:03.0: supports D2
[ 0.126783] pci 0000:02:03.0: PME# supported from D2 D3hot D3cold
[ 0.126844] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.126851] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.126858] pci 0000:00:1e.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.126867] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[ 0.126872] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.126877] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.126893] pci_bus 0000:00: on NUMA node 0
[ 0.126900] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.127228] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.127776] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.145778] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 7 9 10 *11 12 14 15)
[ 0.145908] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 7 9 10 *11 12 14 15)
[ 0.146033] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 7 *9 10 11 12 14 15)
[ 0.146157] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 7 9 *10 11 12 14 15)
[ 0.146281] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled.
[ 0.146410] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled.
[ 0.146538] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled.
[ 0.146667] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 7 9 *10 11 12 14 15)
[ 0.146778] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.146778] vgaarb: loaded
[ 0.146778] vgaarb: bridge control possible 0000:01:00.0
[ 0.146778] PCI: Using ACPI for IRQ routing
[ 0.155270] PCI: pci_cache_line_size set to 64 bytes
[ 0.155374] reserve RAM buffer: 000000000009f000 - 000000000009ffff
[ 0.155379] reserve RAM buffer: 000000003fee0000 - 000000003fffffff
[ 0.155694] hpet clockevent registered
[ 0.155703] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.155714] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.157038] Switching to clocksource hpet
[ 0.157154] pnp: PnP ACPI init
[ 0.157175] ACPI: bus type pnp registered
[ 0.157362] pnp 00:00: [bus 00-ff]
[ 0.157368] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.157373] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.157377] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.157382] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.157387] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.157391] pnp 00:00: [mem 0x3ff00000-0xfebfffff window]
[ 0.157473] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.157599] pnp 00:01: [io 0x0010-0x001f]
[ 0.157604] pnp 00:01: [io 0x0022-0x003f]
[ 0.157608] pnp 00:01: [io 0x0044-0x005f]
[ 0.157612] pnp 00:01: [io 0x0062-0x0063]
[ 0.157616] pnp 00:01: [io 0x0065-0x006f]
[ 0.157620] pnp 00:01: [io 0x0074-0x007f]
[ 0.157623] pnp 00:01: [io 0x0091-0x0093]
[ 0.157627] pnp 00:01: [io 0x00a2-0x00bf]
[ 0.157631] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.157635] pnp 00:01: [io 0x0b78-0x0b7b]
[ 0.157639] pnp 00:01: [io 0x0f78-0x0f7b]
[ 0.157643] pnp 00:01: [io 0x0a78-0x0a7b]
[ 0.157647] pnp 00:01: [io 0x0e78-0x0e7b]
[ 0.157651] pnp 00:01: [io 0x0bbc-0x0bbf]
[ 0.157654] pnp 00:01: [io 0x0fbc-0x0fbf]
[ 0.157658] pnp 00:01: [io 0x04d0-0x04d1]
[ 0.157662] pnp 00:01: [io 0x0294-0x0297]
[ 0.157666] pnp 00:01: [io 0x0800-0x087f]
[ 0.157670] pnp 00:01: [io 0x0880-0x088f]
[ 0.157768] system 00:01: [io 0x0b78-0x0b7b] has been reserved
[ 0.157774] system 00:01: [io 0x0f78-0x0f7b] has been reserved
[ 0.157779] system 00:01: [io 0x0a78-0x0a7b] has been reserved
[ 0.157784] system 00:01: [io 0x0e78-0x0e7b] has been reserved
[ 0.157789] system 00:01: [io 0x0bbc-0x0bbf] has been reserved
[ 0.157794] system 00:01: [io 0x0fbc-0x0fbf] has been reserved
[ 0.157799] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.157804] system 00:01: [io 0x0294-0x0297] has been reserved
[ 0.157808] system 00:01: [io 0x0800-0x087f] has been reserved
[ 0.157813] system 00:01: [io 0x0880-0x088f] has been reserved
[ 0.157819] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.157849] pnp 00:02: [dma 4]
[ 0.157854] pnp 00:02: [io 0x0000-0x000f]
[ 0.157858] pnp 00:02: [io 0x0080-0x0090]
[ 0.157862] pnp 00:02: [io 0x0094-0x009f]
[ 0.157866] pnp 00:02: [io 0x00c0-0x00df]
[ 0.157916] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.157946] pnp 00:03: [io 0x0070-0x0073]
[ 0.157959] pnp 00:03: [irq 8]
[ 0.158009] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.158033] pnp 00:04: [io 0x0061]
[ 0.158084] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.158110] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.158120] pnp 00:05: [irq 13]
[ 0.158174] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.158405] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.158411] pnp 00:06: [io 0x03f7]
[ 0.158419] pnp 00:06: [irq 6]
[ 0.158424] pnp 00:06: [dma 2]
[ 0.158501] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.158823] pnp 00:07: [io 0x03f8-0x03ff]
[ 0.158833] pnp 00:07: [irq 4]
[ 0.158937] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.158937] pnp 00:08: [io 0x02f8-0x02ff]
[ 0.158937] pnp 00:08: [irq 3]
[ 0.158937] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.159106] pnp 00:09: [io 0x0378-0x037f]
[ 0.159111] pnp 00:09: [io 0x0778-0x077b]
[ 0.159120] pnp 00:09: [irq 7]
[ 0.159124] pnp 00:09: [dma 3]
[ 0.159224] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.159389] pnp 00:0a: [io 0x0400-0x04bf]
[ 0.159481] system 00:0a: [io 0x0400-0x04bf] has been reserved
[ 0.159488] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.159537] pnp 00:0b: [mem 0xffb80000-0xffbfffff]
[ 0.159594] pnp 00:0b: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.160138] pnp 00:0c: [mem 0xe0000000-0xefffffff]
[ 0.160245] system 00:0c: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.160251] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.160568] pnp 00:0d: [mem 0x000cf000-0x000cffff]
[ 0.160574] pnp 00:0d: [mem 0x000f0000-0x000f7fff]
[ 0.160578] pnp 00:0d: [mem 0x000f8000-0x000fbfff]
[ 0.160582] pnp 00:0d: [mem 0x000fc000-0x000fffff]
[ 0.160586] pnp 00:0d: [mem 0x3fee0000-0x3fefffff]
[ 0.160590] pnp 00:0d: [mem 0x00000000-0x0009ffff]
[ 0.160595] pnp 00:0d: [mem 0x00100000-0x3fedffff]
[ 0.160599] pnp 00:0d: [mem 0xfec00000-0xfec00fff]
[ 0.160603] pnp 00:0d: [mem 0xfed13000-0xfed1dfff]
[ 0.160607] pnp 00:0d: [mem 0xfed20000-0xfed8ffff]
[ 0.160611] pnp 00:0d: [mem 0xfee00000-0xfee00fff]
[ 0.160615] pnp 00:0d: [mem 0xffb00000-0xffb7ffff]
[ 0.160620] pnp 00:0d: [mem 0xfff00000-0xffffffff]
[ 0.160624] pnp 00:0d: [mem 0x000e0000-0x000effff]
[ 0.160743] system 00:0d: [mem 0x000cf000-0x000cffff] has been reserved
[ 0.160750] system 00:0d: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.160755] system 00:0d: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.160761] system 00:0d: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.160766] system 00:0d: [mem 0x3fee0000-0x3fefffff] could not be reserved
[ 0.160772] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.160777] system 00:0d: [mem 0x00100000-0x3fedffff] could not be reserved
[ 0.160783] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.160788] system 00:0d: [mem 0xfed13000-0xfed1dfff] has been reserved
[ 0.160793] system 00:0d: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.160798] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.160803] system 00:0d: [mem 0xffb00000-0xffb7ffff] has been reserved
[ 0.160808] system 00:0d: [mem 0xfff00000-0xffffffff] has been reserved
[ 0.160813] system 00:0d: [mem 0x000e0000-0x000effff] has been reserved
[ 0.160818] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.160838] pnp: PnP ACPI: found 14 devices
[ 0.160841] ACPI: ACPI bus type pnp unregistered
[ 0.160847] PnPBIOS: Disabled by ACPI PNP
[ 0.200802] pci 0000:01:00.0: BAR 6: assigned [mem 0xf8000000-0xf801ffff pref]
[ 0.200810] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.200817] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.200824] pci 0000:00:01.0: bridge window [mem 0xf4000000-0xfbffffff]
[ 0.200831] pci 0000:00:01.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.200842] pci 0000:02:02.0: BAR 6: assigned [mem 0xfdd00000-0xfdd0ffff pref]
[ 0.200846] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.200852] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.200860] pci 0000:00:1e.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.200867] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[ 0.200902] pci 0000:00:1e.0: setting latency timer to 64
[ 0.200909] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.200914] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.200918] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.200923] pci_bus 0000:01: resource 1 [mem 0xf4000000-0xfbffffff]
[ 0.200927] pci_bus 0000:01: resource 2 [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.200932] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.200936] pci_bus 0000:02: resource 1 [mem 0xfde00000-0xfdefffff]
[ 0.200940] pci_bus 0000:02: resource 2 [mem 0xfdd00000-0xfddfffff 64bit pref]
[ 0.200945] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.200949] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.201088] NET: Registered protocol family 2
[ 0.201195] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.201513] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.202013] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.202312] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.202317] TCP: reno registered
[ 0.202322] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.202336] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.202518] NET: Registered protocol family 1
[ 0.202753] pci 0000:01:00.0: Boot video device
[ 0.202768] PCI: CLS 32 bytes, default 64
[ 0.202860] Unpacking initramfs...
[ 0.633412] Freeing initrd memory: 14336k freed
[ 0.642672] audit: initializing netlink socket (disabled)
[ 0.642700] type=2000 audit(1505503660.636:1): initialized
[ 0.657866] highmem bounce pool size: 64 pages
[ 0.657876] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.658227] VFS: Disk quotas dquot_6.5.2
[ 0.658277] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.658404] msgmni has been set to 1741
[ 0.658751] alg: No test for stdrng (krng)
[ 0.658810] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.658817] io scheduler noop registered
[ 0.658820] io scheduler deadline registered
[ 0.658856] io scheduler cfq registered (default)
[ 0.659078] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.659113] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.659117] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.659870] GHES: HEST is not enabled!
[ 0.659892] isapnp: Scanning for PnP cards...
[ 1.013308] isapnp: No Plug & Play device found
[ 1.013411] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.033817] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.054272] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.075127] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.095689] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.095979] Linux agpgart interface v0.103
[ 1.096468] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.099327] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.099382] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.099602] mousedev: PS/2 mouse device common for all mice
[ 1.099676] rtc_cmos 00:03: RTC can wake from S4
[ 1.099865] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.099899] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 1.100084] TCP: cubic registered
[ 1.100189] NET: Registered protocol family 10
[ 1.100542] Mobile IPv6
[ 1.100548] NET: Registered protocol family 17
[ 1.100556] Registering the dns_resolver key type
[ 1.100638] Using IPI No-Shortcut mode
[ 1.100877] PM: Hibernation image not present or could not be loaded.
[ 1.100901] registered taskstats version 1
[ 1.101413] rtc_cmos 00:03: setting system clock to 2017-09-15 19:27:41 UTC (1505503661)
[ 1.101596] Freeing unused kernel memory: 416k freed
[ 1.101926] Write protecting the kernel text: 3496k
[ 1.101963] Write protecting the kernel read-only data: 984k
[ 1.123132] udevd[49]: starting version 175
[ 1.147165] SCSI subsystem initialized
[ 1.162745] usbcore: registered new interface driver usbfs
[ 1.162794] usbcore: registered new interface driver hub
[ 1.173917] libata version 3.00 loaded.
[ 1.174546] ata_piix 0000:00:1f.1: version 2.13
[ 1.174632] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.197350] microcode: CPU0 sig=0xf44, pf=0x10, revision=0x6
[ 1.200057] usbcore: registered new device driver usb
[ 1.200866] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.201885] scsi0 : ata_piix
[ 1.205400] scsi1 : ata_piix
[ 1.206749] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfb00 irq 14
[ 1.206756] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfb08 irq 15
[ 1.207384] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.207392] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.207435] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.207469] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.211384] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 1.211420] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfdfff000
[ 1.211511] ata2: port disabled--ignoring
[ 1.220888] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.231217] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.231304] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.231311] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.231317] usb usb1: Product: EHCI Host Controller
[ 1.231322] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.231327] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.232505] hub 1-0:1.0: USB hub found
[ 1.232519] hub 1-0:1.0: 8 ports detected
[ 1.232727] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.232797] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.236665] Floppy drive(s): fd0 is 1.44M
[ 1.237877] scsi2 : ata_piix
[ 1.240130] scsi3 : ata_piix
[ 1.241765] ata3: SATA max UDMA/133 cmd 0xfa00 ctl 0xf900 bmdma 0xf600 irq 19
[ 1.241773] ata4: SATA max UDMA/133 cmd 0xf800 ctl 0xf700 bmdma 0xf608 irq 19
[ 1.241943] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.241952] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.241974] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.242011] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff00
[ 1.242086] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.242093] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.242098] usb usb2: Product: UHCI Host Controller
[ 1.242103] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.242108] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.242301] hub 2-0:1.0: USB hub found
[ 1.242314] hub 2-0:1.0: 2 ports detected
[ 1.242458] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.242465] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.242479] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.242511] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fe00
[ 1.242571] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.242579] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.242584] usb usb3: Product: UHCI Host Controller
[ 1.242589] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.242594] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.242763] hub 3-0:1.0: USB hub found
[ 1.242773] hub 3-0:1.0: 2 ports detected
[ 1.242903] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.242910] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.242929] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.242982] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fd00
[ 1.243041] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.243046] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.243050] usb usb4: Product: UHCI Host Controller
[ 1.243054] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.243058] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.243227] hub 4-0:1.0: USB hub found
[ 1.243236] hub 4-0:1.0: 2 ports detected
[ 1.243364] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.243371] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.243385] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.243432] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fc00
[ 1.243490] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.243497] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.243502] usb usb5: Product: UHCI Host Controller
[ 1.243506] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.243510] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.243871] hub 5-0:1.0: USB hub found
[ 1.243882] hub 5-0:1.0: 2 ports detected
[ 1.258482] FDC 0 is a post-1991 82077
[ 1.288925] microcode: CPU1 sig=0xf44, pf=0x10, revision=0x6
[ 1.293574] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.404468] ata3.00: ATA-7: ST3250823AS, 3.03, max UDMA/133
[ 1.404475] ata3.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.404556] ata4.00: ATA-7: ST3250823AS, 3.01, max UDMA/133
[ 1.404567] ata4.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.412337] ata4.00: configured for UDMA/133
[ 1.420285] ata3.00: configured for UDMA/133
[ 1.560328] ata1.00: ATAPI: SONY DVD RW DW-Q31A, LYS2, max UDMA/66
[ 1.560337] ata1.01: ATAPI: SONY DVD-ROM DDU1615, FYS2, max UDMA/33
[ 1.560343] ata1.00: limited to UDMA/33 due to 40-wire cable
[ 1.592213] ata1.00: configured for UDMA/33
[ 1.600404] ata1.01: configured for UDMA/33
[ 1.602080] scsi 0:0:0:0: CD-ROM SONY DVD RW DW-Q31A LYS2 PQ: 0 ANSI: 5
[ 1.602887] scsi 0:0:1:0: CD-ROM SONY DVD-ROM DDU1615 FYS2 PQ: 0 ANSI: 5
[ 1.603273] scsi 2:0:0:0: Direct-Access ATA ST3250823AS 3.03 PQ: 0 ANSI: 5
[ 1.603699] scsi 3:0:0:0: Direct-Access ATA ST3250823AS 3.01 PQ: 0 ANSI: 5
[ 1.604392] ACPI: Fan [FAN] (on)
[ 1.606282] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 1.606318] 8139cp 0000:02:02.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 1.606952] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 1.625571] sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 1.625580] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.626140] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.627152] sr1: scsi3-mmc drive: 4x/40x cd/rw xa/form2 cdda tray
[ 1.627709] sr 0:0:1:0: Attached scsi CD-ROM sr1
[ 1.627927] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.628081] sd 2:0:0:0: [sda] Write Protect is off
[ 1.628089] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.628141] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.628181] sd 3:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.628304] sd 3:0:0:0: [sdb] Write Protect is off
[ 1.628312] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.628367] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.630557] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.630703] sr 0:0:1:0: Attached scsi generic sg1 type 5
[ 1.630846] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 1.630985] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 1.640113] Refined TSC clocksource calibration: 2999.658 MHz.
[ 1.640124] Switching to clocksource tsc
[ 1.655866] sdb: sdb1 sdb2 < sdb5 >
[ 1.656093] usb 1-3: new high-speed USB device number 3 using ehci_hcd
[ 1.656551] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 1.668141] firewire_ohci 0000:02:03.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[ 1.669052] 8139too 0000:02:02.0: eth0: RealTek RTL8139 at 0xec00, 00:13:d3:b2:1e:ea, IRQ 18
[ 1.685086] sda: sda1 sda2 < sda5 sda6 >
[ 1.685723] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.789378] usb 1-3: New USB device found, idVendor=05e3, idProduct=0606
[ 1.789386] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.789392] usb 1-3: Product: USB2.0 Hub
[ 1.789965] hub 1-3:1.0: USB hub found
[ 1.790244] hub 1-3:1.0: 4 ports detected
[ 1.900038] usb 1-4: new high-speed USB device number 4 using ehci_hcd
[ 2.032395] usb 1-4: New USB device found, idVendor=0d8c, idProduct=5200
[ 2.032402] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.144031] usb 1-8: new high-speed USB device number 5 using ehci_hcd
[ 2.168202] firewire_core 0000:02:03.0: created device fw0: GUID 0010dc0000c661aa, S400
[ 2.285145] usb 1-8: New USB device found, idVendor=0781, idProduct=5567
[ 2.285153] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.285158] usb 1-8: Product: Cruzer Blade
[ 2.285162] usb 1-8: Manufacturer: SanDisk
[ 2.285166] usb 1-8: SerialNumber: 4C530000831102002481
[ 2.289948] Initializing USB Mass Storage driver...
[ 2.290163] scsi4 : usb-storage 1-8:1.0
[ 2.290623] usbcore: registered new interface driver usb-storage
[ 2.290628] USB Mass Storage support registered.
[ 2.524027] usb 2-2: new full-speed USB device number 2 using uhci_hcd
[ 2.685127] usb 2-2: New USB device found, idVendor=05e3, idProduct=0604
[ 2.685133] usb 2-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.685138] usb 2-2: Product: USB Hub
[ 2.688197] hub 2-2:1.0: USB hub found
[ 2.690130] hub 2-2:1.0: 4 ports detected
[ 2.768286] usb 1-3.2: new high-speed USB device number 6 using ehci_hcd
[ 3.019669] usb 1-3.2: New USB device found, idVendor=148f, idProduct=2570
[ 3.019675] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.019680] usb 1-3.2: Product: 802.11g WLAN
[ 3.019684] usb 1-3.2: Manufacturer: Ralink
[ 3.092298] usb 1-3.3: new low-speed USB device number 7 using ehci_hcd
[ 3.188797] usb 1-3.3: New USB device found, idVendor=0bc7, idProduct=0006
[ 3.188803] usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.188808] usb 1-3.3: Product: RF receiver
[ 3.188812] usb 1-3.3: Manufacturer: X10 WTI
[ 3.265151] usb 2-2.4: new low-speed USB device number 3 using uhci_hcd
[ 3.288720] scsi 4:0:0:0: Direct-Access SanDisk Cruzer Blade 1.00 PQ: 0 ANSI: 6
[ 3.289937] sd 4:0:0:0: Attached scsi generic sg4 type 0
[ 3.290444] sd 4:0:0:0: [sdc] 30595072 512-byte logical blocks: (15.6 GB/14.5 GiB)
[ 3.291192] sd 4:0:0:0: [sdc] Write Protect is off
[ 3.291199] sd 4:0:0:0: [sdc] Mode Sense: 43 00 00 00
[ 3.291938] sd 4:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.296790] sdc: sdc1
[ 3.299316] sd 4:0:0:0: [sdc] Attached SCSI removable disk
[ 3.457153] usb 2-2.4: New USB device found, idVendor=04f2, idProduct=0420
[ 3.457159] usb 2-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.457164] usb 2-2.4: Product: USB Wireless HID Receiver
[ 3.457168] usb 2-2.4: Manufacturer: Chicony
[ 3.496883] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2.4/2-2.4:1.0/input/input0
[ 3.496986] generic-usb 0003:04F2:0420.0001: input,hidraw0: USB HID v1.11 Keyboard [Chicony USB Wireless HID Receiver] on usb-0000:00:1d.0-2.4/input0
[ 3.565367] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2.4/2-2.4:1.1/input/input1
[ 3.565546] generic-usb 0003:04F2:0420.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Chicony USB Wireless HID Receiver] on usb-0000:00:1d.0-2.4/input1
[ 3.590778] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2.4/2-2.4:1.2/input/input2
[ 3.590915] generic-usb 0003:04F2:0420.0003: input,hidraw2: USB HID v1.11 Mouse [Chicony USB Wireless HID Receiver] on usb-0000:00:1d.0-2.4/input2
[ 3.590960] usbcore: registered new interface driver usbhid
[ 3.590966] usbhid: USB HID core driver
[ 7.318283] device-mapper: uevent: version 1.0.3
[ 7.318930] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 7.684307] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 9.967411] udevd[394]: starting version 175
[ 10.341547] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 10.341558] ACPI: Power Button [PWRB]
[ 10.341651] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 10.341660] ACPI: Sleep Button [SLPB]
[ 10.341770] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 10.341777] ACPI: Power Button [PWRF]
[ 10.393127] parport_pc 00:09: reported by Plug and Play ACPI
[ 10.393190] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 10.775276] intel_rng: FWH not detected
[ 10.794421] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[ 10.804599] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 10.804887] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 10.805147] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 10.805405] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 10.805687] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 10.805970] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 10.806251] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 10.806522] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 10.959527] iTCO_vendor_support: vendor-support=0
[ 11.160213] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 11.160357] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0460)
[ 11.163502] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 11.213657] [drm] Initialized drm 1.1.0 20060810
[ 11.243913] leds_ss4200: no LED devices found
[ 11.371480] wmi: Mapper loaded
[ 11.523545] [drm] nouveau 0000:01:00.0: Detected an NV40 generation card (0x043700a4)
[ 11.527849] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 11.618455] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 11.618461] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 11.618466] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 11.618472] [drm] nouveau 0000:01:00.0: Bios version 05.43.02.76
[ 11.618477] [drm] nouveau 0000:01:00.0: TMDS table version 1.1
[ 11.618773] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 11.618779] [drm] nouveau 0000:01:00.0: DCB version 3.0
[ 11.618784] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000300 00000028
[ 11.618789] [drm] nouveau 0000:01:00.0: DCB outp 01: 04011310 00000028
[ 11.618793] [drm] nouveau 0000:01:00.0: DCB outp 02: 04011312 00000000
[ 11.618798] [drm] nouveau 0000:01:00.0: DCB outp 03: 01122321 006007c3
[ 11.618802] [drm] nouveau 0000:01:00.0: DCB conn 00: 0000
[ 11.618807] [drm] nouveau 0000:01:00.0: DCB conn 01: 2130
[ 11.618812] [drm] nouveau 0000:01:00.0: DCB conn 02: 0214
[ 11.618817] [drm] nouveau 0000:01:00.0: DCB conn 03: 0210
[ 11.618822] [drm] nouveau 0000:01:00.0: DCB conn 04: 0211
[ 11.618827] [drm] nouveau 0000:01:00.0: DCB conn 05: 0213
[ 11.618837] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xE036
[ 11.619090] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xE479
[ 11.631541] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xE94D
[ 11.631564] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xEADF
[ 11.634745] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xEBBD
[ 11.635041] [TTM] Zone kernel: Available graphics memory: 446032 kiB
[ 11.635045] [TTM] Zone highmem: Available graphics memory: 515092 kiB
[ 11.635049] [TTM] Initializing pool allocator
[ 11.635071] [drm] nouveau 0000:01:00.0: Detected 128MiB VRAM (GDDR3)
[ 11.649175] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 11.649319] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 11.707322] [drm] nouveau 0000:01:00.0: unknown connector type 14
[ 11.708565] [drm] nouveau 0000:01:00.0: TV-1 has no encoders, removing
[ 11.709916] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 11.709921] [drm] No driver support for vblank timestamp query.
[ 11.715385] [drm] nouveau 0000:01:00.0: 2 available performance level(s)
[ 11.715396] [drm] nouveau 0000:01:00.0: 0: core 300MHz shader 300MHz memory 1100MHz voltage 1300mV fanspeed 45%
[ 11.715405] [drm] nouveau 0000:01:00.0: 1: core 525MHz shader 525MHz memory 1100MHz voltage 1400mV fanspeed 100%
[ 11.715413] [drm] nouveau 0000:01:00.0: c: core 299MHz shader 299MHz memory 598MHz voltage 1300mV fanspeed 100%
[ 11.717512] [drm] nouveau 0000:01:00.0: 0xD4AE: Parsing digital output script table
[ 11.847309] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x49000, bo f6c57e00
[ 11.847520] fbcon: nouveaufb (fb0) is primary device
[ 11.858929] [drm] nouveau 0000:01:00.0: 0xD4AE: Parsing digital output script table
[ 11.910198] Console: switching to colour frame buffer device 160x64
[ 11.911535] fb0: nouveaufb frame buffer device
[ 11.911539] drm: registered panic notifier
[ 11.911547] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 12.280029] Registered IR keymap rc-medion-x10
[ 12.280193] input: X10 WTI RF receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-3/1-3.3/1-3.3:1.0/rc/rc0/input15
[ 12.280391] rc0: X10 WTI RF receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-3/1-3.3/1-3.3:1.0/rc/rc0
[ 12.280471] input: X10 WTI RF receiver mouse as /devices/pci0000:00/0000:00:1d.7/usb1/1-3/1-3.3/1-3.3:1.0/input/input16
[ 12.280802] usbcore: registered new interface driver ati_remote
[ 12.294856] cfg80211: Calling CRDA to update world regulatory domain
[ 12.488356] usb 1-3.2: reset high-speed USB device number 6 using ehci_hcd
[ 12.800404] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 12.801001] Registered led device: rt2500usb-phy0::radio
[ 12.801080] Registered led device: rt2500usb-phy0::quality
[ 12.802020] usbcore: registered new interface driver rt2500usb
[ 12.954437] cfg80211: World regulatory domain updated:
[ 12.954445] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 12.954450] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 12.954455] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 12.954459] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 12.954463] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 12.954468] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 12.954472] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 12.954476] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 12.954481] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 14.755569] EXT4-fs (dm-0): re-mounted. Opts: (null)
[ 15.028807] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
[ 15.203326] loop: module loaded
[ 15.755136] Adding 2097148k swap on /dev/mapper/LinuxCNC2-swap_1. Priority:-1 extents:1 across:2097148k
[ 17.028594] RPC: Registered named UNIX socket transport module.
[ 17.028600] RPC: Registered udp transport module.
[ 17.028604] RPC: Registered tcp transport module.
[ 17.028607] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.077062] FS-Cache: Loaded
[ 17.105341] NFS: Registering the id_resolver key type
[ 17.105380] FS-Cache: Netfs 'nfs' registered for caching
[ 17.117681] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 19.359500] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input17
[ 20.393795] Bluetooth: Core ver 2.16
[ 20.393837] NET: Registered protocol family 31
[ 20.393843] Bluetooth: HCI device and connection manager initialized
[ 20.393848] Bluetooth: HCI socket layer initialized
[ 20.393851] Bluetooth: L2CAP socket layer initialized
[ 20.393862] Bluetooth: SCO socket layer initialized
[ 20.435343] Bluetooth: RFCOMM TTY layer initialized
[ 20.435358] Bluetooth: RFCOMM socket layer initialized
[ 20.435363] Bluetooth: RFCOMM ver 1.11
[ 20.492700] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.492707] Bluetooth: BNEP filters: protocol multicast
[ 20.734223] lp0: using parport0 (interrupt-driven).
[ 20.914166] ppdev: user-space parallel port driver
[ 23.226640] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 23.312473] 8139too 0000:02:02.0: eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 67.097855] I-pipe: head domain RTAI registered.
[ 67.097865] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 67.098016] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 67.098022] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12498588, CLK_FREQ 2999629000, CPU_FREQ 2999629000
[ 67.098027] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 67.098032] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498588, 12498588, 12441000
[ 67.144868] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 67.144927] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 67.144936] RTAI[sched]: hard timer type/freq = APIC/12498588(Hz); default timing: oneshot; linear timed lists.
[ 67.144942] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999629000 hz.
[ 67.144946] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 67.160078] RTAI[math]: loaded.
[ 70.045366] RTAI[math]: unloaded.
[ 70.048276] SCHED releases registered named ALIEN PEDV$D
[ 70.054824] RTAI[malloc]: unloaded.
[ 70.152026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 70.154918] I-pipe: head domain RTAI unregistered.
[ 70.155027] RTAI[hal]: unmounted.
[ 417.854963] I-pipe: head domain RTAI registered.
[ 417.854973] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 417.855068] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 417.855074] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12498588, CLK_FREQ 2999629000, CPU_FREQ 2999629000
[ 417.855079] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 417.855084] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498588, 12498588, 12367500
[ 417.870649] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 417.870707] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 417.870716] RTAI[sched]: hard timer type/freq = APIC/12498588(Hz); default timing: oneshot; linear timed lists.
[ 417.870722] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999629000 hz.
[ 417.870726] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 417.892483] RTAI[math]: loaded.
[ 420.569110] RTAI[math]: unloaded.
[ 420.572325] SCHED releases registered named ALIEN PEDV$D
[ 420.578342] RTAI[malloc]: unloaded.
[ 420.676027] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 420.678948] I-pipe: head domain RTAI unregistered.
[ 420.679216] RTAI[hal]: unmounted.
[ 441.463911] I-pipe: head domain RTAI registered.
[ 441.463922] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 441.464224] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 441.464233] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12498588, CLK_FREQ 2999629000, CPU_FREQ 2999629000
[ 441.464238] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 441.464244] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498588, 12498588, 12394000
[ 441.476637] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 441.476699] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 441.476708] RTAI[sched]: hard timer type/freq = APIC/12498588(Hz); default timing: oneshot; linear timed lists.
[ 441.476714] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999629000 hz.
[ 441.476718] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 441.486540] RTAI[math]: loaded.
[ 444.157615] RTAI[math]: unloaded.
[ 444.160818] SCHED releases registered named ALIEN PEDV$D
[ 444.166853] RTAI[malloc]: unloaded.
[ 444.264032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 444.267257] I-pipe: head domain RTAI unregistered.
[ 444.267366] RTAI[hal]: unmounted.
[ 532.886077] I-pipe: head domain RTAI registered.
[ 532.886088] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 532.886184] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 532.886190] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12498588, CLK_FREQ 2999629000, CPU_FREQ 2999629000
[ 532.886195] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 532.886201] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498588, 12498588, 12343500
[ 532.901553] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 532.901616] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 532.901624] RTAI[sched]: hard timer type/freq = APIC/12498588(Hz); default timing: oneshot; linear timed lists.
[ 532.901630] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999629000 hz.
[ 532.901634] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 532.921561] RTAI[math]: loaded.
[ 535.579726] RTAI[math]: unloaded.
[ 535.582944] SCHED releases registered named ALIEN PEDV$D
[ 535.594226] RTAI[malloc]: unloaded.
[ 535.692025] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 535.694933] I-pipe: head domain RTAI unregistered.
[ 535.695042] RTAI[hal]: unmounted.
[ 851.741408] I-pipe: head domain RTAI registered.
[ 851.741417] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 851.741578] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 851.741584] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12498588, CLK_FREQ 2999629000, CPU_FREQ 2999629000
[ 851.741589] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 851.741595] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498588, 12498588, 12352500
[ 851.756848] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 851.756915] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 851.756923] RTAI[sched]: hard timer type/freq = APIC/12498588(Hz); default timing: oneshot; linear timed lists.
[ 851.756929] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999629000 hz.
[ 851.756933] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 851.772231] RTAI[math]: loaded.
[ 854.451439] RTAI[math]: unloaded.
[ 854.454308] SCHED releases registered named ALIEN PEDV$D
[ 854.459704] RTAI[malloc]: unloaded.
[ 854.556025] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 854.558981] I-pipe: head domain RTAI unregistered.
[ 854.559093] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
TASK=milltask
HALUI=
DISPLAY=axis
4574
[ 0.097076] dummy:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
TASK=milltask
HALUI=
DISPLAY=axis
4574
[ 0.097076] dummy:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
TASK=milltask
HALUI=
DISPLAY=axis
4574
[ 0.097076] dummy:
- Online
- Thank you received: 1369
15 Sep 2017 19:54 #99006
Replied by Todd Zuercher on topic LinuxCNC terminated with error
The important part of all that error message you posted is here:And it is saying that on the 35th line of your HAL File named "sim_hardware.hal" you have an error. The error is that a pin named "parport.0.pin-02-out-invert-fake" on that line does not exist.
Could you give us some details about your Machine setup? You said that you are trying to convert the machine from Mach3. How is the computer connected to the machine?
If it is a simply plugged into a parallel port on the computer. Then Stepconfig can be used to import the Mach3 XML configuration file, and hopefully set up most of the configuration automatically.
Have you tried this?
15 Sep 2017 20:38 #99008
by Moptop
Replied by Moptop on topic LinuxCNC terminated with error
Yes it is plugged into the parallel.
I was trying to set it up as a XYZ router but I am complete new to Linux and it has been a very steep learning curve. It is supposed to be easy moving from Windows to Linux. I will try and correct the error and then try to import my Mach3 XML file. Thanks for the speedy reply to my problem I will reply later if it works out OK. Thanks
- Online
15 Sep 2017 20:59 #99010
Who ever said it is or should be easy to switch from Windows to Linux? There is a lot of differences to get used to between the two systems. The biggest is the difference in how file systems are mounted and addressed. But from simply a gui user stand point it isn't much different from switching from Windows to Mac or Android. But the differences are real and it takes a little getting used to.
It looks like the machine config you are working with is a simulation config, and as such it will be difficult to convert to running real hardware. I suggest starting over from scratch with Stepconfig.
The simulation configs are very useful though for playing arround with and learning how Linuxcnc works and how configurations can be built.
Time to create page: 0.909 seconds
