Reboot Required to Load Again
- Engineer Dwayne
29 Sep 2017 01:54 #99594
by Engineer Dwayne
Reboot Required to Load Again was created by Engineer Dwayne
If I close and restart linuxcnc I get a parport not ready error. See file.
The only way to recover from this error is to reboot my machine.
I am running version 2.5 and two parallel ports, one internal and one on a second plug is card. My machine is an older dell Pentium 4.
03 Oct 2017 21:28 #99856
Replied by andypugh on topic Reboot Required to Load Again
That's not normal.
It seems like something is not letting go of the parport.
If you do abefore starting LinuxCNC, during LinuxCNC running and after exiting LinuxCNC do you see anything suspicious?
If you do a
lsmod | grep par
- MPCEngineer
02 Mar 2018 16:12 #106852
by MPCEngineer
Replied by MPCEngineer on topic Reboot Required to Load Again
Hi. Did you find an answer for this?
I am new to LinuxCNC and have loaded version 2.5.0 onto an IBM thinkpad laptop. Its driving the steppers okay but after every run of LinuxCNC or Stepconf I have to reboot the computer if I want to run LinuxCNC or Stepconf again.
I am using the live Ubuntu 10.04 CD as my IBM thinkpad does not have a DVD reader.
MPC.
MPC.
02 Mar 2018 16:58 #106856
2.5.0 is now very old. (1st April 2012).
You should be able to update LinuxCNC to the latest version (2.7.12) without updating the operating system by following the instructions here:
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.6
then
linuxcnc.org/docs/2.7/html/getting-start...dating-linuxcnc.html
(Pay special attention to section 3.2 as this might have a direct bearing on your issue)
then
Time to create page: 0.279 seconds
