5v drive enable on mesa board
18 Jan 2018 20:46 #104698
Replied by PCW on topic 5v drive enable on mesa board
change
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
to
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=3 sserial_port_0=00xxxx"
to
18 Jan 2018 21:28 - 18 Jan 2018 21:28 #104703
Thats what I did! The relay switches 5V stolen from one of my stepgens to the enable button to disable the drives when in estop
Replied by rodw on topic 5v drive enable on mesa board
or maybe ill just be lazy and put a relay on one of the outputs.
Last edit: 18 Jan 2018 21:28 by rodw.
18 Jan 2018 22:41 #104707
by zmcdona1
Replied by zmcdona1 on topic 5v drive enable on mesa board
i changed it to 3 and i also added
setp hm2_5i25.0.gpio.007.is_output true
it flip flopped which pins are 5v and grnd on the 3rd axis but it does not turn io7 on and off when the machine on/off is toggled.
is there anything else i need to add?
- The Feral Engineer
- Thank you received: 22
02 Feb 2021 15:11 - 02 Feb 2021 15:12 #197434
by The Feral Engineer
Replied by The Feral Engineer on topic 5v drive enable on mesa board
Really late to the party here, but Michael at emco confirmed my notion that the drive enable signal is actually designed to be 24v, but it somehow works with only 5. They were nice enough to send me all of the schematics for the A01 version of this setup and the drive enable is part of a safety circuit that runs through x110 and x121 of the old AC95
Last edit: 02 Feb 2021 15:12 by The Feral Engineer.
03 Feb 2021 16:33 #197568
by bevins
Replied by bevins on topic 5v drive enable on mesa board
Why don't you just use an output to energize relay and put "net machine-is-on " in custom.hal and wire that relay to pass whatever voltage your drivers need for enable? then move on to the next step.
03 Feb 2021 16:41 #197570
Now two of us are replying to a three year old thread... At least I'm not the only one
Time to create page: 0.316 seconds
