preguntas sobre 5axis bridgemill configuración
28 Aug 2020 13:14 #179828
by OT-CNC
Replied by OT-CNC on topic questions about 5axis bridgemill setup
Is the W axis needed/suggested to make the 5axiskins work? I'm still not fully grasping this.
21 Dec 2020 08:59 #192612
by Profed81
Replied by Profed81 on topic preguntas sobre 5axis bridgemill configuración
The vismach Bridgemill ini file contains a section where it says 5axiskins, does that kinematics work? Sorry for the stupid question
21 Dec 2020 09:03 #192613
by Profed81
The cinematic 5axi skins is in some folder inside my computer? Or is it only on github?
- Thank you received: 5945
21 Dec 2020 11:58 #192625
Replied by tommylight on topic preguntas sobre 5axis bridgemill configuración
Some of the 5 axis sims are included with vismach, so start LinuxCNC from the menu or just type linuxcnc in a terminal, a new window will open, on the left side choose SIM then one of the 5 axis vismah config then click on ok.
21 Dec 2020 12:06 #192628
by Profed81
Where can I find a tutorial on how to install the 5axiskins kinematics?
21 Dec 2020 12:38 #192635
No need, it should be included.
Time to create page: 0.169 seconds
