Mesa 7i76e CR2 red led on at power up
- DaveRosario
- Topic Author
29 Apr 2019 09:19 #132259
by DaveRosario
Mesa 7i76e CR2 red led on at power up was created by DaveRosario
Hi Guys,
I have a 7i76e that it was working really good until today. It just stopped connecting to Linuxcnc. So when I check the card.
It has the CR1 in Yellow and the CR2 in Red. I tried different PSUs and switched down the jumper W9, nothing happened.
I read I might have to re-flash it? the board is only 3 moths old.
Please let me know what you think and if you know how to flash it.
Thanks,
David
Thanks,
David
29 Apr 2019 13:40 #132286
by pl7i92
Replied by pl7i92 on topic Mesa 7i76e CR2 red led on at power up
hi it needs to be flashed i think to
first can you ping the 7i76e
does it respond on the ip
then simply get the bitfile from mesa
if you do not have mesaflash
To install mesaflash:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
sudo add-apt-repository "deb linuxcnc.org/ jessie base 2.7-uspace"
sudo apt-get update
sudo apt-get install mesaflash
check the bitfile if it is one there
mesaflash --device 7i76e --addr IP --readhmid
to flash the firmware (using the correct bit file for your application)
sudo mesaflash --device 7i76e --addr 10.10.10.10 --write BITFILE
to reload the firmware
mesaflash --device 7i76e --addr 10.10.10.10 --reload
POWERCYCLE THE CARD
reread again
sudo apt-get update
POWERCYCLE THE CARD
reread again
29 Apr 2019 14:33 #132295
Replied by PCW on topic Mesa 7i76e CR2 red led on at power up
If both /DONE and /INIT LEDs are stuck on after power cycling the 7I76E in both EEPROM select jumper positions. The card must be returned to Mesa for evaluation
- DaveRosario
- Topic Author
29 Apr 2019 16:51 #132303
by DaveRosario
Replied by DaveRosario on topic Mesa 7i76e CR2 red led on at power up
Thanks for the reply guys,
So, Both CR1 and CR2 are on when I power up the board, no communication to the board is available so I can't ping the board. Jumper W9 makes no difference. It's weird because it was working fine.
I'll call mesa today to see if I can send it back.
Thanks,
David
Thanks,
David
02 May 2019 19:21 #132559
Received the card, there's some non-obvious issue with FPGA/fLash chip communication so we are replacing the card.
- DaveRosario
- Topic Author
02 May 2019 19:28 #132561
by DaveRosario
Cool! Thanks!
- Huntermountain
27 Jan 2021 19:29 #196800
by Huntermountain
Replied by Huntermountain on topic Mesa 7i76e CR2 red led on at power up
I know this is an old topic, but unfortunately, I've run into the same problem. I've had the card for a few months, and I just got things running like they should. And now this...Tried both W9 positions, but I only get the red and orange LEDs, and no communication via ethernet. Is there a solution for this problem?
- DaveRosario
- Topic Author
27 Jan 2021 20:20 #196805
by DaveRosario
Give Mesa Electronics a call, they have an excellent support and customer service.
Regards,
David
Regards,
David
27 Jan 2021 20:50 #196808
CR2 on (?DONE) is a bad sign , it means the FPGA wont load a configuration at startup
I would email Mesa and ask for a RMA# to evaluate/repair/replace the card
- Thank you received: 5932
27 Jan 2021 21:28 #196823
Replied by tommylight on topic Mesa 7i76e CR2 red led on at power up
They have the best support, bar none!Give Mesa Electronics a call, they have an excellent support and customer service.
Time to create page: 0.111 seconds
