Latency mesage SOLVED !
11 Oct 2019 10:41 #147690
by macsddau
Latency mesage was created by macsddau
- Thank you received: 6268
11 Oct 2019 12:41 #147698
Replied by tommylight on topic Latency mesage
Open the ini file in a text editor and change
Base_period
to something larger, try 100000 ( one hundred thousand )
Base_period
- Thank you received: 1422
11 Oct 2019 16:01 #147710
Replied by Todd Zuercher on topic Latency mesage
What PC motherboard and CPU are you using?
Have you turned off all power saving features in the Bios?
It is important to have the PC configured correctly when running real-time operations, but some computers just are not well suited for it. (maybe you have a bad one.)
If you are trying to use an older PC, failing hardware, especially hard-drives, can cause latency problems.
13 Oct 2019 04:49 #147787
by macsddau
Replied by macsddau on topic Latency mesage
Hi
The PC is made with :
- ASRock mini ITX J3355B mother board
- 4GB Ram G.Skill SO-DIMM DDR3L 1333 MHz
- Radeon HD4650 Graphic card
- WD Green 120GB SSD Drive
I have turn off all power saving feature in the BIOS. But I will check it.
13 Oct 2019 06:25 #147794
by macsddau
There is not a lot of settings in the BIOS, all fans are turned to full speed. Mother board has no fan and chassis fans are connected to power supply.
Checked !I have turn off all power saving feature in the BIOS. But I will check it.
13 Oct 2019 06:27 #147795
by macsddau
Changing to this value will remove the message but it is not sure that the CNC will work fine.Open the ini file in a text editor and change
Base_period
13 Oct 2019 08:54 #147802
It will work fine, so change it.
While you are getting the error, that causes lost steps, usually not noticeable if the latency is not bad, very noticeable if latency is really bad.
13 Oct 2019 09:14 #147806
by macsddau
Ok value changed to 100000.
I can't check the result, milling machine is not built yet .
Wait and see...
Wait and see...
13 Oct 2019 15:06 - 13 Oct 2019 15:06 #147821
by macsddau
This affect the max speed.
For this time go back to 50000.
Last edit: 13 Oct 2019 15:06 by macsddau.
13 Oct 2019 19:57 #147825
by Leon82
Replied by Leon82 on topic Latency mesage
You will have to test it out but speed with lost steps is worse than slow rapid speed
Time to create page: 0.136 seconds
