machine config overview questions
25 Aug 2010 13:19 #3872 by willeo6709
I have a "family" of machines I would like to try EMC on. They are all vertical machining centers, 2 are 3 ax, 2 are 4 ax, all have vector motor spindles, resolvers all around. I also like ladder logic for i/o troubleshooting and sequencing events. I like servo control boards with real dac's and was looking at Vigilant Technology PCI boards. I was hoping to use an automation direct plc for the non real time i/o amd modbus it into emc. so basically the machine:
15kw spindle vector motor with resolver
(3) 30 newton meter servo motors with resolver
(1) 10 newton meter servo motor with encoder( 4th axis)
umbrella style drum toolchanger
chip conveyors
surface sensing and tool length probing
48 inputs
32 outputs
The mesa boards seem more popular but I am leery of not have a dac chip on the board for the 0-10vdc analog outputs. All the boards I looked at, none could handle 80 i/0 points plus the servo/ spindle so I am looking at multiple boards or 1 board and modbus to a plc for the rest. I do like the fanuc i/o rack model A I have on some machines with fanuc 16's, easy to replace 1 module. I am new to both emc and linux. I do have a box loaded up with linux rt and have played with it a bit.
Looking for advise on where to go on the hardware side of this project.
26 Aug 2010 11:16 #3878 by andypugh
willeo6709 wrote:
I I was hoping to use an automation direct plc for the non real time i/o amd modbus it into emc.
Classic Ladder (inside EMC2) might be an alternative to an external PLC. It makes communications a little easier as there are fewer layers.
PWM to analogue is relatively straightforward, and seems to work well as the PID will generally compensate for any non-linearity in the conversion.
All the boards I looked at, none could handle 80 i/0 points plus the servo/ spindle so I am looking at multiple boards.
The Mesa 3X20 has144 IO Pins, but needs a PCI-e connection:
www.mesanet.com/fpgacardinfo.html
However, multiple boards (and maybe a mixture of Pico and Mesa cards) might be better. That way you could mix-and-match firmwares with perhaps one board dedicated to GPIO and the other to motion control.
26 Aug 2010 11:59 #3882 by willeo6709
when I spoke to the guys at mesa about their stuff, the 144 io card still would not do 80 io plus 4 ax plus a vector spindle, as each servo took at least 10 i/o spots as I recall. I know they were the ones who said I could use their board for motion and then modbus in the non time critical stuff.
26 Aug 2010 15:00 #3885 by andypugh
I am sure they know their stuff, but it rather depends on the driver used. Lowest pin count would be enable, PWM + Direction as outputs and encoder phases A, B and Z for input for a total of 6.
Using the Mesa servo drives (like the 7i39) the pin count is somewhat higher and breaking out unused IO lines for GPIO is a little complex, and it is much simpler to dedicate one FPGA card header to each 2-axis driver card, then use a separate card for GPIO.
The requirements rather depend on your existing drives, motors and feedback systems.
Have you looked at the Pico systems devices?
pico-systems.com/motion.html
26 Aug 2010 15:08 #3886 by PCW
The 3X20 has 144 I/O bits so should be able to control 8 servo Axis (2X 7I33TAs) and have 96 I/O bits left
if you used 4x 7I37TAs with these 96 bits, you would have 32x 1A 24VDC outputs and 64x isolated 4-24VDC inputs.
If you used 4x OPTO22 24 I/O module racks with the 96 free I/O bits, you could have 96 I/O points with a per point choice of AC in, AC out, DC in and DC out.
The 7I48 is now supported in master. It supports 6 Axis on one (24 bit) I/O connector instead of the 7I33s 4 axis. With that you can have more free
I/O = 120 free I/O points with a 3X20
This still may not be ideal since its likely most of your I/O points are not real time so could be done with a modbus interfaced PLC
How does the Fanuc IO rack model A interface? Maybe it can be re-used...
26 Aug 2010 15:19 #3887 by willeo6709
If these machines had fanuc's on them I would not be changing..... the i/o is all on proprietary interfaces boards now... all analog ac brushless servo drives with a vector motor spindle, resolvers all around the 3 axes plus spindle. The 4th axis is an ac analog brushless with encoder and an electrocraft max 430 drive. The rest of the machine is kollmorgens... which have their moments.
I like ladder - my fanuc's all have it and its great for troubleshooting (plus I can edit the ladder in most of my fanuc's if needed). Classic ladder would work, I need to get more into that. I'll look at the boards in PCW's post.
Time to create page: 0.219 seconds
