- General
- General LinuxCNC Questions
- Issues with Remapped M6 subroutine and o-sub routines when running from line
05 Oct 2020 18:44 #184992
by Henk
Hi.
Not sure if anyone had this problem and if there is a solution.
I noticed this behaviour previously with an M6 remapped configuration when starting a program using the run from line option. Basically if there are tool change calls prior to that line, they are all called and changed by the ATC consecutively until the correct tool is loaded again, then it will continue with the remInder of the program.
I noticed the same behaviour with another program that calls a simple probe sub repeatedly at various coordinates to check a job setup and work offset. If I start this program from a random line, the interpreter first runs all the subs from the start of the program until it gets to the selected start line, then continues.
At first I thought this is a remap issue, but now it seems to happen when there are calls to external subroutines from a program.
Is there a way to fix this? Have I done something stupid, or do we just have to live with this for now?
I'm running 2.7.15
Henk
I'm running 2.7.15
Henk
The following user(s) said Thank You: HalaszAttila
- Thank you received: 5983
10 Oct 2020 21:58 #185648
Replied by tommylight on topic Issues with Remapped M6 subroutine and o-sub routines when running from line
The only thing i can think off is to disable the lookahead, but might not be the best solution, or might not be a solution at all.
Normally it is set to look 50 lines ahead, IIRC, it was a long time ago since i dabbled in it.
02 Mar 2021 04:27 #200758
by Henk
Replied by Henk on topic Issues with Remapped M6 subroutine and o-sub routines when running from line
Hi.
Is this a common problem? I have not found a solution to this yet.
Maybe there is a simple sollutions but I don't know where to start looking...
Henk
Henk
02 Mar 2021 09:57 #200769
by rmu
Replied by rmu on topic Issues with Remapped M6 subroutine and o-sub routines when running from line
There is no simple solution that I know of. github.com/LinuxCNC/linuxcnc/issues/246
- General
Time to create page: 0.169 seconds
