Making 0-10V output work with spindle in HAL
- sushantkurren
- Topic Author
26 Oct 2020 06:17 #187277
by sushantkurren
Making 0-10V output work with spindle in HAL was created by sushantkurren
Hi there,
I currently have this breakout board wired up to my CNC: www.aliexpress.com/item/1801916509.html which seem to be ubiquitous over the internet.
My issue is I currently have the 0-10V + GND on the right side of the board attached to my VFD 0-10V/GND inputs.
I also have P17 connected as 'Spindle On' and have connected that to the "FWD" pin on the VFD. When I type M3 and M5 in LinuxCNC, the relay triggers (I can hear it), so that's working fine.
However when I read the documentation regarding 0-10V Spindle Control on: linuxcnc.org/docs/2.5/html/examples/spindle.html I am unable to figure out what the <your DAC pin name> would be. I am unsure what the name of the 0-10V pin would be called in the HAL and all P1-17 ports are accounted for.
Any ideas on how to wire this setup correctly or whether I should be using a different HAL setup?
Very appreciated, thank you.
26 Oct 2020 09:54 #187285
Replied by Aciera on topic Making 0-10V output work with spindle in HAL
Can you post your HAL and INI files?
- sushantkurren
- Topic Author
26 Oct 2020 10:01 #187286
by sushantkurren
Replied by sushantkurren on topic Making 0-10V output work with spindle in HAL
Here you are. Thanks
26 Oct 2020 10:20 #187288
I would expect your board uses a PWM signal from one of the pins on the parallel port.
Then you would connect that pin in HAL as in the docs:
loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
net spindle-speed-cmd motion.spindle-speed-out => pwmgen.0.value
net spindle-on motion.spindle-on => pwmgen.0.enable
net spindle-pwm pwmgen.0.pwm => parport.0.pin-09-out
# Set the spindle's top speed in RPM
setp pwmgen.0.scale 1800
- sushantkurren
- Topic Author
26 Oct 2020 10:25 #187289
by sushantkurren
Oh great, that makes sense.
Where would the PWM then be wired into?
26 Oct 2020 11:57 #187298
Do you have any documentation for that board?
- sushantkurren
- Topic Author
26 Oct 2020 13:46 #187308
by sushantkurren
This is what I have on that front - not the most informative.
26 Oct 2020 14:37 - 26 Oct 2020 14:53 #187314
Found another bit of information from another vendor and it looks like PWM might be meant to be fed into P1 of the parallel port:
Can you actually reverse the spindle as well or is that "Spindle ON/OFF control interface" just an on/off relay contact?
[edit]
I just noticed that you use pin1 for a motor. Can you move the motors?
Ok looks like its just "Spindle ON/OFF"
Another manual: certainly looks like pin1 is the PWM
enes.ir/shop/image/catalog/Products/EN01...CNCBreakoutBoard.pdf
[edit]
Last edit: 26 Oct 2020 14:53 by Aciera.
26 Oct 2020 16:13 #187325
by MalteS
Replied by MalteS on topic Making 0-10V output work with spindle in HAL
This board expects PWM on Pin1. Your hal file uses Pin 9.
Make sure to connect the 12-24V on the right hand side of the board and set the jumper for P17 - Motor direction correctly.
- sushantkurren
- Topic Author
26 Oct 2020 21:02 #187340
by sushantkurren
Interesting, so are you recommending wiring the P1 PWM to "FWD" on the VFD? Or what's the idea here
Time to create page: 0.271 seconds
