Plasma voltage 1:1 on Herocut 55i
01 Nov 2020 08:29 #187994
by bevins
Plasma voltage 1:1 on Herocut 55i was created by bevins
I have a herocut 55i with CNC interface. The only issue is the voltage has a ratio of 1:1.
What is the preferred way to get the voltage divided to what would be needed with Plasmac and Mesa's THCAD-10?
01 Nov 2020 08:47 #187995
by phillc54
Replied by phillc54 on topic Plasma voltage 1:1 on Herocut 55i
A common way is two 1M resistors, checkout the THCAD10 section here:
linuxcnc.org/docs/2.8/html/plasma/plasma...ng_the_divider_ratio
01 Nov 2020 13:12 #188005
by bevins
Can I convert the THCAD-10 to a THCAD-300? That way I won't need a divider.
Replied by bevins on topic Plasma voltage 1:1 on Herocut 55i
01 Nov 2020 21:36 #188048
Before you panic too much, measure the resistance from the Herocut output pin to each electrode terminal. I would expect them to put a resistor in line to get the current down to a non lethal level. If thats the case add the two up and add one more scaling resistor in the control panel at the thcad to make up the required scaling resistance.
I'm not sure the thcad-300 is the anwser here if they have already added resistors.
Replied by rodw on topic Plasma voltage 1:1 on Herocut 55i
01 Nov 2020 21:39 #188049
Update: I would expect 100k resistance on each pin from Everlast and Thermal Dynamics
01 Nov 2020 22:07 #188054
by bevins
Thanks Rod,
I'll check when I get to it. I am changing out those pesky useless Chinese drives and motors. I bought a set of DYN4 ac servo and drives.
This project is a never ending money pit. Cant wait to get rid of it.....lol
Thanks Rod,
- Thank you received: 5934
01 Nov 2020 22:47 #188061
Replied by tommylight on topic Plasma voltage 1:1 on Herocut 55i
Yes, but then you would need to de-solder and solder back 10 resistor, with low tolerance !Can I convert the THCAD-10 to a THCAD-300? That way I won't need a divider.
Time to create page: 0.159 seconds
