setup installed linuxcnc on virtual box
03 Nov 2020 12:20 #188209
by mad10
setup installed linuxcnc on virtual box was created by mad10
i installed linuxcnc on virtual box . İt gives this warning when i run after select ini file.
linuxcnc :290how can i fix?
/home/mad/Desktop/linuxcnc-dev/scripts/linuxcnc: line 290: cd: $'/home/mad/linuxcnc/configs/sim.axis\n.\n.\n~': No such file or directory
/bin/grep: /home/mad/linuxcnc/configs/sim.axis/axis.ini
can't save ~/.linuxcncrc: No such file or directory
Machine configuration directory is '/home/mad/linuxcnc/configs/sim.axis/axis.ini
can't save ~'
Machine configuration file is '.linuxcncrc'
Could not find ini file '/home/mad/linuxcnc/configs/sim.axis/axis.ini
can't save ~/.linuxcncrc'
linuxcnc :290
cd "$(dirname $inifile)" ;# for the function() subprocess only
03 Nov 2020 13:15 #188213
Replied by andypugh on topic setup installed linuxcnc on virtual box
I don't think thus is a virtualbox problem.
What version of LinuxCNC? How did you install it?
I assume that the axis.ini file does exist? You didn't say.
03 Nov 2020 13:24 #188214
by mad10
Replied by mad10 on topic setup installed linuxcnc on virtual box
i am using 2.9.0 pre linuxcnc
My install guide:
yes i have ini file . It created by linuxcnc when i first run
My install guide:
03 Nov 2020 13:32 #188215
Can LinuxCNC run any sample configs?
If you start linuxcnc from the command line with an absolute link to the INI does it work?
linuxcnc.org/docs/2.8/html/man/man1/linuxcnc.1.html
Is there any particular reason that you are building from source rather than running precompiled packages?
Maybe you forgot the . ./scripts/rip-environment script that needs to be run before starting a LinuxCNC Run In Place build?
03 Nov 2020 13:56 #188218
by mad10
1. question: İ dont understand
2.question: Some file need to permission but i solved. İt worked
3.question: Just, I learning linuxcnc because i want to develeop linuxcnc for better system . (I am open if you have suggestions)
4. Yes .I ran
4. Yes .I ran
- Thank you received: 5934
03 Nov 2020 14:37 #188228
Replied by tommylight on topic setup installed linuxcnc on virtual box
Topic title changed to reflect more info.
Time to create page: 0.185 seconds
