"Following error" on a slow toolpath that's worked before?
  • JetForMe
  • JetForMe's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Nov 2020 02:14 #188948 by JetForMe
I got a following error on my X and Z axes just now running a toolpath I've run several times before, on this and different similar parts. I forget what it means for there to be one on a stepper axis (i.e. no feedback). The X axis wasn't doing much, the Z was bopping up and down a little, but nothing out of the ordinary; well below it's velocity and accel, I think.
This has possibly scrapped my part. I'd like to know how to be more robust in this situation. Any advice?
11 Nov 2020 02:16 #188949 by PCW
Can you post your hal and ini files?
  • JetForMe
  • Elite Member
  • Elite Member
11 Nov 2020 07:28 #188959 by JetForMe
11 Nov 2020 12:52 #188987 by PCW
My suggestion would be to widen the following error limits
1.
If LinuxCNC gets a Ethernet RX packet timeout, it will use old
position feedback data , possible resulting on a FE as large
as servo_thread_period x velocity. So my guess is that you
are getting rare timeouts which cause an apparent FE.
Note that this is not a real position error.
A max_ferror of 0.6mm will prevent triggering a following error
at your 600 mm/s and 1 ms servo thread period if you drop a packet.
2.
It may also be that FF2 needs to be tuned a little better
to meet your narrow FE settings
There is a way to deal a bit more cleverly with occasional timeouts
by using the packet error bit to change the position feedback
to the commanded position if there has been a timeout. This prevents
bogus FEs from stale position data.
This has the side benefit of not making bogus velocity corrections
in case of dropped packets (and resulting stale feedback data).
# switch fb data to command on packet error:
net perror hm2_[HOSTMOT2](BOARD).0.packet-error => mux2.0.sel mux2.1.sel mux2.2 .sel
# Joint 0 connections
net emcmot.00.pos-cmd joint.0.motor-pos-cmd => pid.0.command mux2.0.in1
net fb0 mux2.0.in0 <= hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb
# feedback position to motion is forced to be commanded position if there's a packet error
net motor.00.pos-fb <= mux2.0.out joint.0.motor-pos-fb pid.0.feedback
  • JetForMe
  • Elite Member
  • Elite Member
14 Nov 2020 01:03 #189284 by JetForMe
Oh wow, this is probably the area I understand the least. It sounds like you're suggesting, rather than doing 1 & 2, I do the mux-on-error thing you show, right?
14 Nov 2020 04:49 #189293 by PCW
I would try the simplest thing first (widen the following error to
maxvel*servo_thread_period and min_ferror to maybe 10X larger)
  • JetForMe
  • Elite Member
  • Elite Member
15 Nov 2020 02:29 #189422 by JetForMe
MIN_FERROR should be 10x larger than FERROR? This seems to go against what this page shows: wiki.linuxcnc.org/cgi-bin/wiki.pl?Following_Error
15 Nov 2020 02:34 #189423 by PCW
Sorry I meant about 10x larger than it was.
Time to create page: 0.372 seconds
