- LinuxCNC
- General LinuxCNC Questions
- Out of memory error running a program (but no apparent consequences)?
- JetForMe
- Thank you received: 27
12 Nov 2020 01:23 #189078
by JetForMe
Out of memory error running a program (but no apparent consequences)? was created by JetForMe
After doing a bunch of stuff to upgrade and then get my LinuxCNC back to working, I was running a test with a non-trivial program I've run several times prior to this update. A minute or so into running, I noticed these errors in the output:
Just the two times, and it didn't seem to actually affect anything running. Top didn't show any particularly high memory use:
This is from the buildbot package install. Anything I should be worried about?
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1550, in __call__
return self.func(*args)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 599, in callit
func(*args)
File "/usr/bin/axis", line 556, in actual_tkRedraw
self.tkRedraw_perspective()
File "/usr/bin/axis", line 516, in tkRedraw_perspective
self.redraw_perspective()
File "/usr/lib/python2.7/dist-packages/rs274/glcanon.py", line 353, in inner
return f(self, *args, **kw)
File "/usr/lib/python2.7/dist-packages/rs274/glcanon.py", line 613, in redraw_perspective
glFlush() # Tidy up
error: (1285, 'out of memory')
func(*args)
glFlush() # Tidy up
error: (1285, 'out of memory')Just the two times, and it didn't seem to actually affect anything running. Top didn't show any particularly high memory use:
top - 17:23:13 up 16 min, 5 users, load average: 1.05, 1.84, 1.37
Tasks: 244 total, 1 running, 243 sleeping, 0 stopped, 0 zombie
%Cpu(s): 1.6 us, 1.5 sy, 0.0 ni, 96.1 id, 0.0 wa, 0.0 hi, 0.8 si, 0.0 st
MiB Mem : 17.4/7925.9 [|||||||||||||||||| ]
MiB Swap: 0.0/8071.0 [ ]This is from the buildbot package install. Anything I should be worried about?
- LinuxCNC
Time to create page: 0.162 seconds
