- General
- General LinuxCNC Questions
- 7i76e - TB2 not working - no axis motor movement - but TB3 and rest working fine
20 Nov 2020 20:45 #189922
Replied by PCW on topic 7i76e - TB2 not working - no axis motor movement - but TB3 and rest working fine
Not sure what you mean by mixed mode but, yes, the 10 stepgen signals on the 7I76E are FPGA signals with translation (buffering) to high current 5V outputs.
The parallel expansion ports are full compatible with standard parallel port BOBs
(they are pinout compatible and have 5V tolerant I/O)
- Mike_Eitel
- Thank you received: 185
20 Nov 2020 21:08 #189926
by Mike_Eitel
Replied by Mike_Eitel on topic 7i76e - TB2 not working - no axis motor movement - but TB3 and rest working fine
Thx
Now i understand that on my 7i76e i must have W5 up = 5 V tolerant.
And mixed mode i understand in a way that u use some free pins, not used for stepper or encoder, via a serial protokol to comunicate with a 7i76 to the rest of io's
I think such a 7i76e & 7i76 plus a 7i37 is very interesting combo!
Mike
Mike
20 Nov 2020 21:53 #189929
Yes, there is a local (on card) sserial channel on the 7I76E
that communicates with the isolated field I/O section
The following user(s) said Thank You: Mike_Eitel
28 Nov 2020 10:33 #190500
by denhen89
Replied by denhen89 on topic 7i76e - TB2 not working - no axis motor movement - but TB3 and rest working fine
Hello,
i just want to inform you guys that my 7i76e is working again perfectly.
Both ICs got replaced.
Both broken ICs had a small hole on the top.
Thanks, especially to PCW for telling what is broken and what are the correct ICs. Also thanks to Mike
- General
