Warnig & Errors @ boot, Is it affecting latency ?
- macsddau@linuxcnc
- Topic Author
- Thank you received: 28
22 Nov 2020 07:17 #190027
by macsddau@linuxcnc
I have targeting to remove a maximum of warning and errors at boot time.
There are some lines that I haven't find a solution. Is it affecting latency performances ?Do you know where to find information for solving these messages ?
sudo journalctl -p warning
-- Logs begin at Mon 2018-05-21 02:05:34 CEST, end at Sun 2020-11-22 08:09:24 CE
mai 21 02:05:34 R993CNC kernel: pci 0000:02:00.0: can't set Max Payload Size to
mai 21 02:05:34 R993CNC kernel: i801_smbus 0000:00:1f.1: can't derive routing fo
mai 21 02:05:34 R993CNC kernel: i801_smbus 0000:00:1f.1: PCI INT A: not connecte
mai 21 02:05:35 R993CNC kernel: CRAT table not found
mai 21 02:05:35 R993CNC kernel: kvm: disabled by bios
nov. 21 23:16:43 R993CNC avahi-daemon[406]: chroot.c: open() failed: No such fil
nov. 21 23:16:43 R993CNC avahi-daemon[399]: Failed to open /etc/resolv.conf: Inv
nov. 21 23:16:56 R993CNC lightdm[728]: Error getting user list from org.freedesk
nov. 21 23:16:57 R993CNC lightdm[749]: Error getting user list from org.freedesk
lines 1-11/11 (END)
22 Nov 2020 11:29 - 22 Nov 2020 11:31 #190036
by Himarc3D
Replied by Himarc3D on topic Warnig & Errors @ boot, Is it affecting latency ?
The last 4 errors i have the same, i tried few solutions over internet and i still have the errors. My understanding about the last 4 errors don’t affect latency.
I not spend time to fix this because its okay for what I understand so ill ignore
Last edit: 22 Nov 2020 11:31 by Himarc3D.
The following user(s) said Thank You: macsddau@linuxcnc
- Thank you received: 5944
22 Nov 2020 13:54 #190043
Replied by tommylight on topic Warnig & Errors @ boot, Is it affecting latency ?
I do not think those should affect latency.
Time to create page: 0.114 seconds
