Joint following error right after clicking on Machine Power ON (7i97 LCNC 2.9)
30 Nov 2020 20:08 #190703 by PCW
You should never need to isolate the encoder
You must not connect an analog output to drive ground. Isolating
the encoder would not help as you would get interference between
axis analog signals. If connecting the encoder lowers the analog output
you have a wiring error.
If you wish to reverse the analog output polarity (as Y seems to need),
you do this by changing the sign of the PWM scale (this might be set
by OUTPUT_SCALE depending on the hal.ini file structure), NOT by
swapping AOUT and GND
