QTDragon - Popup keyboard not working in REF offset popup.
27 Nov 2020 00:10 #190384
by JohnnyCNC
I used QTDragon + touch screen to actually make parts for the first time today. I found that the popup keyboard doesn't work when in the popup where you set an offset after finding an edge. REFY -> Set.
27 Nov 2020 04:08 #190394
Replied by cmorley on topic QTDragon - Popup keyboard not working in REF offset popup.
I confirm the problem.
There is a work around if you are willing to modify the .ui file in designer.
on the screenOptions widget make sure property calculatorDialog_option is checked.
on all the axisToolButtons change the 'dialog_code_string' from ENTRY to CALCULATOR
Then you'll get a touchscreen friendly calculator - you might even like it better.
Chris
Chris
27 Nov 2020 12:57 #190434
by JohnnyCNC
Thanks Chris, I'll give it a try. I just beginning to learn how to modify the UI.
Replied by JohnnyCNC on topic QTDragon - Popup keyboard not working in REF offset popup.
Chris
27 Nov 2020 14:14 #190442
by JohnnyCNC
Much better. Thanks Chris.
28 Nov 2020 02:47 #190482
I was thinking of making it standard actually.
The following user(s) said Thank You: JohnnyCNC
28 Nov 2020 20:59 #190550
by JohnnyCNC
The new popup calculator screen looks great.
Thanks Chris.
Thanks Chris.
30 Jan 2021 17:59 #197168
by persei8
Replied by persei8 on topic QTDragon - Popup keyboard not working in REF offset popup.
A bit late to the party, but another workaround is to modify the handler code with the following:
In the def initialized__ method, add:
Then modify the following method:
This will use the ENTRY method if the virtual keyboard is disabled and the CALCULATOR method if enabled.
It works with versions 2.8 and 2.9. If you want the chosen method to be permanent, then use the SCREENOPTIONS parameter like Chris said above.
Jim
self.chk_use_virtual_changed(self.w.chk_use_virtual.isChecked())
def chk_use_virtual_changed(self, state):
codestring = "CALCULATOR" if state else "ENTRY"
for i in ("x", "y", "z", "a"):
self.w["axistoolbutton_" + i].set_dialog_code(codestring)
if not state:
self.w.stackedWidget_dro.setCurrentIndex(0)
Jim
30 Jan 2021 18:25 #197170
by JohnnyCNC
Thanks Jim,
I will have a look at that. There was another place that I wanted to use the calculator but couldn't find the spot to sent the property. I have been working on my workflow using an M6 remap with a mix of repeatable tools and variable length tools. I will get back to this in the near future.
Time to create page: 0.150 seconds
