Z height compensation problem (with GcodeRipper)
29 Nov 2020 19:15 #190620
by Jocman
Z height compensation problem (with GcodeRipper) was created by Jocman
Hi all.
I'm having some problem with my z height compensation procedure.
I use Scorch's GcodeRipper to fix my gcode files.
I'm doing some work test on some PMMA
Situation: 3 gcode in sequence:
- 1st: a rounded rectangle dept 0.2 mm with end mill 1 mm
- 2nd: an engraved text dept 0,15 mm with 0.1 10° bit
- 3rd: some holes and the final cut with a 3.175 mm single flute.
My z probe is direct into the chuck and z zeroed (this way the probe offset is 0 for all the axis)
This is what I do for each file:
- open in GcodeRipper,set the total probe points and export the probe file.
- launch the probe file in linuxcnc and generate the points file
- load the points file in GcodeRipper, fix the original gcode and save the fixed one.
I don't zero the probe each time (i think is useless,isn't?)
Well,at this point, i mount the first bit (the end mill 1 mm) in the spindle, z zero the bit, load the 1st fixed file in linuxcnc and start the job.
The bit doesn't "carve" anything.....the first pass stays at about 0.6 mm from the surface. If i stop the spindle (and the job) and go to Z0,the bit touch normally the surface.
I tried twice to remake the "ripping" procedure,but no changes...
At the end i tried to "cheat": after z zeroing,i went to Z0 and manually re-zeroed Z, giving an offset of 0.5 and launched the job again.
I expected the bit to work propeperly (or at least to touch the surface),but nothing to do: the job goes exactly as the first time and at the same height (0.6 mm)
Honestly,i don't understand why this behaviour....
Any suggestion?
Andrea
Any suggestion?
Andrea
04 Dec 2020 13:30 #191025
by Jocman
Replied by Jocman on topic Z height compensation problem (with GcodeRipper)
Maybe found the issue.
Z speed to high.
'cause I'm using a microswitch based probe, I'm pretty sure the problem is related to bouncing / ghost trigger problems.
At low (very low....) speed (0.05 mm/s), the probe is almost reliable, but just at 0.5 mm/s it seems to be problematic...
Need to look for a solution....
Z speed to high.
Time to create page: 0.062 seconds
