Adding a 5th Joint ?
04 Dec 2020 00:13 #190993
by kramerda
Adding a 5th Joint ? was created by kramerda
I'm currently running LinuxCNC 2.8 with PlasmaC AXIS GUI, on an Rpi4, 4GB.
Using Mesa 7i76e and THCAD-10,
I have 3 Axis today (XYZ) with 2 Y axis joints. Total =4.
So far works fine for the minimal testing I've done.
I'd like to add a 2nd X Axis joint (new total =5).
Any issues (configuration? latency? ) before I invest in the extra hardware?
Thanks,
Dennis
Thanks,
Dennis
- Online
- Thank you received: 5933
04 Dec 2020 00:53 #190999
Replied by tommylight on topic Adding a 5th Joint ?
If it is working with 4 it will work with 5.
04 Dec 2020 03:00 #191004
by kramerda
Replied by kramerda on topic Adding a 5th Joint ?
Thank you - we'll give it a try.
Time to create page: 0.066 seconds
