Predefined Named Parameters #<_tool_offset>
16 Dec 2020 00:23 - 16 Dec 2020 00:28 #192085
by alkabal
Predefined Named Parameters #<_tool_offset> was created by alkabal
Hi
Is there a way using "Predefined Named Parameters" #<_tool_offset> to know if this is G43 or G43.1 or G43.2 ?
linuxcnc.org/docs/2.8/html/gcode/overvie...ned-named-parameters
linuxcnc.org/docs/2.8/html/gcode/g-code.html#gcode:g43.1
I think like G40 this is 490 430 431 432
Br
Br
Last edit: 16 Dec 2020 00:28 by alkabal.
- Thank you received: 5945
27 Dec 2020 13:11 #193296
Replied by tommylight on topic Predefined Named Parameters #<_tool_offset>
Bump
28 Dec 2020 04:23 - 28 Dec 2020 04:38 #193341
by alkabal
Replied by alkabal on topic Predefined Named Parameters #<_tool_offset>
I have do some test and unfortunatly this report only 0/1 (i'm not 100% if this work fine or not)
Thanks for bump
edit : github.com/LinuxCNC/linuxcnc/issues/1010
Thanks for bump
Last edit: 28 Dec 2020 04:38 by alkabal.
Time to create page: 0.230 seconds
