2.8 not working
- raggielyle1@gmail.com
21 Dec 2020 10:53 #192618
by raggielyle1@gmail.com
2.8 not working was created by raggielyle1@gmail.com
I need help, please.
I have been running 2.7 without problems.
I've done a fresh 2.5 install and used my 2.7 config. The program automatically updated the config and created an "old" folder but now nothing works.
I've tried creating a new config with stepconf using the same settings as in 207 but that too does not work.
Bruce
Bruce
21 Dec 2020 10:59 #192620
Replied by cmorley on topic 2.8 not working
Need more info. Error messages and maybe post the config files.
22 Dec 2020 06:11 #192784
Replied by raggielyle1@gmail.com on topic 2.8 not working
Thank you for your speedy response.
Attached are the in and hal files.
Thank you for your kind help.
Regards
BRuce
Regards
BRuce
- Thank you received: 5945
22 Dec 2020 10:20 #192798
Replied by tommylight on topic 2.8 not working
Error mesage ?
23 Dec 2020 05:54 #192929
Here is the log file.
This is whats happening:
The z axis works but very very slowly. The x and y motors make a sound but the gantry wont move. A sort of shuddering.
I'm using the same machine. The 2.7 installation is running under Wheezy. My 2.8 installation is running under Buster on an SSD.
Thanks once again for everyone's kind help - don't for a moment think that it's not appreciated.
I gave up on a new configuration using stepconf as it would not even come to life with the power on button
Kind Regards
Bruce
Kind Regards
Bruce
23 Dec 2020 10:43 #192947
The file is a dxf2gcode debug file so does not help, but since the motors are making noises, it most probably has to do the the velocities and acceleration and scaling not set properly.
Use the jog velocity slider to lower the jog rate and jog the machine, if it works edit the ini file to more reasonable values.
Time to create page: 0.360 seconds
