spindle scale
29 Dec 2020 10:50 #193409
by jefsaro
spindle scale was created by jefsaro
hello, after several weeks without being able to work on my fanuc milling machine, I am in finalization, the hitachi vfd works, on the other hand I can not configure the right speed, I do not understand how it works, I have tried several config , but the I hold. Can you help me?
N= 6000tr/min
encoder 1024
N= 6000tr/min
encoder 1024
29 Dec 2020 13:08 #193418
Replied by cmorley on topic spindle scale
Any other information?
30 Dec 2020 05:17 #193489
by jefsaro
Replied by jefsaro on topic spindle scale
vfd wj200, i works whit 0-10v
30 Dec 2020 05:37 #193491
I see you are using a 5i25 anything else?
can you describe the machine mechanics a bit? I see you have selected multiple spindle gears.
What have you tried?
what happens now?
You might want to give us all the config files.
Can not make bricks if we have no clay
what happens now?
30 Dec 2020 07:59 #193497
by jefsaro
hello, I found the problem, it was the frequency of the motor on the vfd, it was 60 hz and therefore limited the engine to 1800tr, I put 200 hz and I have the 6000tr.
thank you all
thank you all
Time to create page: 0.358 seconds
